- Mar 3, 2016
- 13
- 1
- 13
Nothing can ruin cruising in you ride faster then annoying interior noise.
TKO has 2 fantastic solutions!
We all love the sound when we "get on it", but there are some sounds that are just not that appealing.
Tire / road noise is one of them. This is a problem in certain states like TX, CA, Fl..etc because of either concrete roads or the top surface used. Certain aftermarket exhaust can also create fatigue over time/long trips.
The BLOCKIT "Qiuck & Quiet" mat helps take the edge off both of these problems in seconds.
Simply place the pre cut mat in your trunk.
This is NOT a thin single layer mat! The BLOCKIT is a unique 4 layer combination of real acoustical soundproofing. It measures 1” inch thick! This combination of materials absorbs and suppresses unpleasant sounds. It quickly helps quiet your interior in seconds. But still lets your sweet exhaust noise come through when you mat it.
No adhesive so you can always take the BLOCKIT out for track events. Place it back in for the ride home. Perforated section to remove for sub-woofer cars.
All raw materials are from the USA!
Made in the USA!
All under strict ISO 9001 regulations!
Patent Pending
This item will be ready for shipping in 2 weeks. We are taking pre orders now with a discounted price.
Regular Price $169.95
Forum Discount $149.99
Read more & order securely here: http://store.tkoperformance.com/20muqqusodew.html
_________________________________________________________________________________
To Take It To The Next Level Of Quiet Check Out DeadMats!
Thin, Light weight, extremely effective in reducing vibrations and cabin noise!
Blockit Dead Mats use a unique technology to eliminate unwanted vibration & noise in your vehicle. It’s not your typical mass loaded vinyl. The thin light weight mats are a highly damped proprietary mineral filled viscoelastic polymer which provides outstanding sound & vibration reduction. At only .445 lbs per sq ft the performance to weight ratio is amazing. The bottom line is the Blockit DeadMats are light weight and are designed to simply not vibrate!
The self adhesive backing makes for a simply cut and stick application. You can either completely cover an area, just a portion of an area or strategically place them with outstanding results. Blockit Dead Mats can be stacked to double up on vibration and noise reduction. Blockit Dead Mats, are fantastic on their own or in addition to compliment the Blockit Quick & Quiet Mats.
Simply cut, peel & stick.
We know there are some areas that require damping and are not hidden or buried under carpet. The Blockit Dead Mats have a textured surface layer which is durable and has a nice clean look when exposed.
Doors
Trunk/Cargo area
Under Seat/floor
The kits come in:
5 18"x32" sheets (20 Sq ft)
Click here http://store.tkoperformance.com/bldema185sh2.html
9 18"x32" sheets (36 sq ft)
Click here http://store.tkoperformance.com/bldema18x329.html
If you have any questions, please feel free to contact us either by phone 1800 778 9898 or via email [email protected]
Thank you!!
