O.K. LOOK I KNOW THIS IS REALLY LONG BUT IT'S THE SOURCE CODE FOR THE MAIN PAGE. SOMEWHERE IN HERE IT SHOULD TELL YOU BACKGROUND MUSIC IS XXXXXXX.WAV OR .MP3 OR SOMETHING LIKE THAT. I ONLY LOOKED REAL QUICK AND DIDN'T SEE IT.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html><!-- InstanceBegin template="/Templates/int.dwt" codeOutsideHTMLIsLocked="false" -->
<head>
<!-- saved from url=(0013)about:internet -->
<!-- InstanceBeginEditable name="doctitle" -->
<title>Saleen, Inc.</title>
<!-- InstanceEndEditable -->
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link href="border.css" rel="stylesheet" type="text/css">
<script language="JavaScript" type="text/JavaScript">
function mmLoadMenus() {
if (window.mm_menu_0715171219_0) return;
window.mm_menu_0715171219_0 = new Menu("root",150,25,"Verdana, Arial, Helvetica, sans-serif",12,"#ffffff","#ffffff","#2d3641","#66581b","left","middle",3,0,500,-5,7,true,true,true,6,false,false);
mm_menu_0715171219_0.addMenuItem("About*Saleen*Inc.*","location='about_saleen.htm'");
mm_menu_0715171219_0.addMenuItem("About*Steve*Saleen*","location='about_steve_saleen.htm'");
mm_menu_0715171219_0.addMenuItem("Chronological*History*","location='history.htm'");
mm_menu_0715171219_0.addMenuItem("Upcoming*Events*","location='upcoming_events.htm'");
mm_menu_0715171219_0.addMenuItem("Press*Releases","location='press_releases.htm'");
mm_menu_0715171219_0.addMenuItem("Location*/*Contact*","location='location_contact.htm'");
mm_menu_0715171219_0.hideOnMouseOut=true;
mm_menu_0715171219_0.menuBorder=0;
mm_menu_0715171219_0.menuLiteBgColor='#2d3641';
mm_menu_0715171219_0.menuBorderBgColor='#2d3641';
mm_menu_0715171219_0.bgColor='#000000';
window.mm_menu_0715180950_1_1 = new Menu("S281**Coupe",188,25,"Verdana, Arial, Helvetica, sans-serif",12,"#ffffff","#ffffff","#2d3641","#66581b","left","middle",3,0,500,0,0,true,true,true,6,false,false);
mm_menu_0715180950_1_1.addMenuItem("S281*-*3*Valve","location='s281_3v.htm'");
mm_menu_0715180950_1_1.addMenuItem("S281*-*Supercharged","location='s281_sc.htm'");
mm_menu_0715180950_1_1.addMenuItem("S281*-*Extreme","location='s281_e.htm'");
mm_menu_0715180950_1_1.hideOnMouseOut=true;
mm_menu_0715180950_1_1.menuBorder=0;
mm_menu_0715180950_1_1.menuLiteBgColor='#2d3641';
mm_menu_0715180950_1_1.menuBorderBgColor='#2d3641';
mm_menu_0715180950_1_1.bgColor='#000000';
window.mm_menu_0715180950_1_2 = new Menu("S281*Convertible",188,25,"Verdana, Arial, Helvetica, sans-serif",12,"#ffffff","#ffffff","#2d3641","#66581b","left","middle",3,0,500,0,0,true,true,true,6,false,false);
mm_menu_0715180950_1_2.addMenuItem("S281*-*3*Valve*Convt.","location='s281_3v_convt.htm'");
mm_menu_0715180950_1_2.addMenuItem("S281*-*Supercharged*Convt.","location='s281_sc_convt.htm'");
mm_menu_0715180950_1_2.addMenuItem("S281*-*Extreme*Convt.","location='s281_e_convt.htm'");
mm_menu_0715180950_1_2.hideOnMouseOut=true;
mm_menu_0715180950_1_2.menuBorder=0;
mm_menu_0715180950_1_2.menuLiteBgColor='#2d3641';
mm_menu_0715180950_1_2.menuBorderBgColor='#2d3641';
mm_menu_0715180950_1_2.bgColor='#000000';
window.mm_menu_0715180950_1 = new Menu("root",188,25,"Verdana, Arial, Helvetica, sans-serif",12,"#ffffff","#ffffff","#2d3641","#66581b","left","middle",3,0,500,0,0,true,true,true,6,false,false);
mm_menu_0715180950_1.addMenuItem("Vehicles","location='vehicles.htm'");
mm_menu_0715180950_1.addMenuItem("Saleen*S7","location='saleen_s7_main.htm'");
mm_menu_0715180950_1.addMenuItem(mm_menu_0715180950_1_1,"location='s281_coupe.htm'");
mm_menu_0715180950_1.addMenuItem(mm_menu_0715180950_1_2,"location='s281_convertible.htm'");
mm_menu_0715180950_1.addMenuItem("N20*Focus*-*S121","location='n2o_s121.htm'");
mm_menu_0715180950_1.addMenuItem("Dealer*Locator","location='dealerLocator.aspx'");
mm_menu_0715180950_1.hideOnMouseOut=true;
mm_menu_0715180950_1.childMenuIcon="main_nav/arrows.gif";
mm_menu_0715180950_1.menuBorder=0;
mm_menu_0715180950_1.menuLiteBgColor='#2d3641';
mm_menu_0715180950_1.menuBorderBgColor='#2d3641';
mm_menu_0715180950_1.bgColor='#000000';
window.mm_menu_0716141602_2 = new Menu("root",190,25,"Verdana, Arial, Helvetica, sans-serif",12,"#ffffff","#ffffff","#2d3641","#66581b","left","middle",3,0,500,-5,7,true,true,true,6,false,false);
mm_menu_0716141602_2.addMenuItem("Team*Saleen","location='team_saleen.htm'");
mm_menu_0716141602_2.addMenuItem("Membership*Information","location='membership_info.htm'");
mm_menu_0716141602_2.addMenuItem("Saleen*Owners*&*Fan*Club","location='saleen_owners_club.htm'");
mm_menu_0716141602_2.hideOnMouseOut=true;
mm_menu_0716141602_2.menuBorder=0;
mm_menu_0716141602_2.menuLiteBgColor='#2d3641';
mm_menu_0716141602_2.menuBorderBgColor='#2d3641';
mm_menu_0716141602_2.bgColor='#000000';
mm_menu_0716141602_2.writeMenus();
} // mmLoadMenus()
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a
.indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a;}}
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a)&&x.oSrc;i++) x.src=x.oSrc;
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers.document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
<!-- InstanceBeginEditable name="head" -->
<style type="text/css">
.style1 { font-family: Arial, Helvetica, sans-serif;
font-size: 10px;
.style2 {color: #CCCCCC}
.style3 {font-family: Arial, Helvetica, sans-serif; font-size: 10px; color: #CCCCCC; }
</style>
<script language="JavaScript1.2" src="main_nav/mm_menu.js"></script>
</head>
<body bgcolor="#000000" text="#FFFFFF" link="#FFCC00" vlink="#FF6600" alink="#FFCC00" leftmargin="0" topmargin="0" marginwidth="0" marginheight="0" onLoad="MM_preloadImages('images/b_about_steve_on.gif','images/b_history_on.gif','images/b_location_on.gif','main_nav/main_nav_r1_c1_f2.gif','main_nav/main_nav_r1_c3_f2.gif','main_nav/main_nav_r1_c5_f2.gif','main_nav/main_nav_r1_c7_f2.gif','main_nav/main_nav_r1_c9_f2.gif','main_nav/main_nav_r1_c11_f2.gif','main_nav/main_nav_r1_c13_f2.gif')">
<table width="580" border="0" align="center" cellpadding="0" cellspacing="0" class="border">
<tr>
<td><table width="580" border="0" align="center" cellpadding="0" cellspacing="0">
<tr>
<td><img src="images/top_left.gif" width="438" height="59" border="0" usemap="#Map"></td>
<td><img src="images/top_right.jpg" width="332" height="59"></td>
</tr>
</table>
<div align="center">
<table width="580" border="0" cellspacing="0" cellpadding="1">
<tr>
<td valign="top"><!-- InstanceBeginEditable name="flash_area" -->
<table width="541" border="0" cellspacing="0" cellpadding="0">
<tr>
<td><object classid="clsid27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,29,0" width="770" height="230">
<param name="movie" value="2005_homepage_animation.swf">
<param name="quality" value="high">
<embed src="2005_homepage_animation.swf" quality="high" pluginspage="http://www.macromedia.com/go/getflashplayer" type="application/x-shockwave-flash" width="770" height="230"></embed>
</object></td>
</tr>
</table>
<!-- InstanceEndEditable --></td>
</tr>
</table>
<table width="300" border="0" cellspacing="0" cellpadding="0">
<tr>
<td><script language="JavaScript1.2">mmLoadMenus();</script>
<table border="0" cellpadding="0" cellspacing="0" width="770">
<!-- fwtable fwsrc="main_nav_crop_6.png" fwbase="main_nav.gif" fwstyle="Dreamweaver" fwdocid = "742308039" fwnested="0" -->
<tr>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="121" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="25" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="97" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="18" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="59" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="26" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="91" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="24" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="17" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="95" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="19" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="72" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="9" height="1" border="0"></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="1" height="1" border="0"></td>
</tr>
<tr>
<td><a href="index.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('main_nav_r1_c1','','main_nav/main_nav_r1_c1_f2.gif',1);"><img name="main_nav_r1_c1" src="main_nav/main_nav_r1_c1.gif" width="121" height="27" border="0" alt=""></a></td>
<td><img name="main_nav_r1_c2" src="main_nav/main_nav_r1_c2.gif" width="25" height="27" border="0" alt=""></td>
<td><a href="about_saleen.htm" onMouseOut="MM_swapImgRestore();MM_startTimeout()" onMouseOver="MM_showMenu(window.mm_menu_0715171219_0,0,27,null,'main_nav_r1_c3');MM_swapImage('main_nav_r1_c3','','main_nav/main_nav_r1_c3_f2.gif',1);"><img name="main_nav_r1_c3" src="main_nav/main_nav_r1_c3.gif" width="97" height="27" border="0" alt=""></a></td>
<td><img name="main_nav_r1_c4" src="main_nav/main_nav_r1_c4.gif" width="18" height="27" border="0" alt=""></td>
<td><a href="vehicles.htm" onMouseOut="MM_swapImgRestore();MM_startTimeout()" onMouseOver="MM_showMenu(window.mm_menu_0715180950_1,0,27,null,'main_nav_r1_c5');MM_swapImage('main_nav_r1_c5','','main_nav/main_nav_r1_c5_f2.gif',1);"><img name="main_nav_r1_c5" src="main_nav/main_nav_r1_c5.gif" width="59" height="27" border="0" alt=""></a></td>
<td><img name="main_nav_r1_c6" src="main_nav/main_nav_r1_c6.gif" width="26" height="27" border="0" alt=""></td>
<td><a href="http://commerce.saleen.com/" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('main_nav_r1_c7','','main_nav/main_nav_r1_c7_f2.gif',1);"><img name="main_nav_r1_c7" src="main_nav/main_nav_r1_c7.gif" width="91" height="27" border="0" alt=""></a></td>
<td><img name="main_nav_r1_c8" src="main_nav/main_nav_r1_c8.gif" width="24" height="27" border="0" alt=""></td>
<td><a href="saleen_racing.htm" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('main_nav_r1_c9','','main_nav/main_nav_r1_c9_f2.gif',1);"><img name="main_nav_r1_c9" src="main_nav/main_nav_r1_c9.gif" width="97" height="27" border="0" alt=""></a></td>
<td><img name="main_nav_r1_c10" src="main_nav/main_nav_r1_c10.gif" width="17" height="27" border="0" alt=""></td>
<td><a href="team_saleen.htm" onMouseOut="MM_swapImgRestore();MM_startTimeout()" onMouseOver="MM_showMenu(window.mm_menu_0716141602_2,0,27,null,'main_nav_r1_c11');MM_swapImage('main_nav_r1_c11','','main_nav/main_nav_r1_c11_f2.gif',1);"><img name="main_nav_r1_c11" src="main_nav/main_nav_r1_c11.gif" width="95" height="27" border="0" alt=""></a></td>
<td><img name="main_nav_r1_c12" src="main_nav/main_nav_r1_c12.gif" width="19" height="27" border="0" alt=""></td>
<td><a href="downloads.htm" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('main_nav_r1_c13','','main_nav/main_nav_r1_c13_f2.gif',1);"><img name="main_nav_r1_c13" src="main_nav/main_nav_r1_c13.gif" width="72" height="27" border="0" alt=""></a></td>
<td><img name="main_nav_r1_c14" src="main_nav/main_nav_r1_c14.gif" width="9" height="27" border="0" alt=""></td>
<td><img src="main_nav/spacer.gif" alt="" name="undefined_2" width="1" height="27" border="0"></td>
</tr>
</table></td>
</tr>
</table>
<div align="left">
<table width="770" border="0" cellspacing="0" cellpadding="0">
<tr>
<td valign="top"><!-- InstanceBeginEditable name="body" -->
<tr>
<td><object classid="clsid27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,29,0" width="770" height="240">
<param name="movie" value="2005_homepage_below.swf">
<param name="wmode" value="transparent">
<embed src="2005_homepage_below.swf" width="770" height="240" quality="high" pluginspage="http://www.macromedia.com/go/getflashplayer" type="application/x-shockwave-flash" wmode="transparent"></embed>
</object></td>
</tr>
</table>
</tr>
</table>
</div>
<tr>
<td><!-- InstanceBeginEditable name="footer" -->
<table width="600" border="0" cellspacing="0" cellpadding="0">
<tr>
<td><img src="images/footer_2.jpg" width="770" height="72"></td>
</tr>
<tr>
<td><span class="style3"> <a href="about_saleen.htm">About
Saleen</a> | <a href="vehicles.htm">Vehicles</a> | <a href="http://commerce.saleen.com/">Parts
and Gear</a> | <a href="owners_corner.htm">Owners Corner</a> | <a href="saleen_racing.htm">Saleen
Racing</a> | <a href="downloads.htm">Downloads</a></span> <span class="style3">| <a href="careers.htm">Careers</a> </span> <font size="1" face="Arial, Helvetica, sans-serif"><a href="http://www.pixelmotion.net" target="_blank"> Website
by www.pixelmotion.net</a></font></td>
</tr>
