Rolling And Rocking.
Yes. Roller rockers, followers, etc are function much different than flat tappets. Whereas flat tappets have a "break-in" period during which the lobe of the camshaft and hydraulic lifter wear each other down and harden, rollers simply act like a bearing. All that friction and wear is eliminated. Unless you can see visible damage or wear to the old cams and followers, it will work fine. If you'd like, I have a pair of cams off my '06 I'd be willing to part with. They had about 40,000 when I swapped them out.
Keep in mind it has the aftermarket cams, but at idle it's deep and fairly loud, light throttle is smooth and even and a bit louder, cruise quiets down a bit but has some drone over 2200, and wide open gets a bit higher pitched and absolutely screams. At idle, most people compare it to an old muscle car.
