Roush/SVO FRPP Supercharger. From my understanding, this unit was made available on the stage 3 1998 Roush Mustangs. I contacted Roush when I bought this unit and they have no record of how may Stage 3 98's were made. I haven't really seen a lot of these blowers with the "Roush" casting on the top. I have only seen them say SVO or Ford Racing. Which tells me that this unit is very rare.
Now this blower will work on non-PI or PI 2V motors (96-04) or any other 2V Ford Engines. Originally for Non-PI but did port work to work on either or with NO LEAKS. I have a PI motor and currently making 333hp and 341tq on a stock motor with just a Steeda cold air intake, 90mm Lightning MAF, and a tune. There is much more to be had with other after market parts. (heads, cam, meth, etc)
Here is what you will get:
Blower unit (m112) with stock pulley (seen 8 psi with CAI - I have dyno sheet)
30lb Injectors
Lightning AIT sensor - installed in blower
2 different fuel rails / 1 non-return style - 1 return style
Vacuum lines for blower
Steeda Cold Air Intake - No MAF - filter needs a cleaning
New alternator for 96-98 Mustang with pigtail
Brand New Serp Belt
New Radiator Hose
All bolts - I will label what is for what in ziplock bags
All brackets - except driver's side coil bracket - I shaved mine to prevent the belt from hitting.
Throttle cable for 99-04 Mustang
Custom coolant crossover in rear with coolant return pipe
Base piggy back tune - see below
Install instructions
What you will need:
90mm Lightning MAF
Fuel pump
Custom dyno tune
I also have a base tune that you can plug into your computer with stock MAF. I ran this tune for 2 weeks prior to getting a custom dyno tune. The car ran a little rich and performed good. I never got into it in fear of breaking something.
Now for the fun stuff - I'm looking to get $2000.00 - Shipping and PP extra. I have over 3 into it with all the work that I did to this unit for it work with either or motor. This is a very fun blower and you get instant TQ out of the hole.
PM me for more pics or questions
30lb Injectors
Brand New Serp Belt
New Radiator Hose
What you will need:
90mm Lightning MAF
Fuel pump
Custom dyno tune
