For sale is a pair of stage II ported PI heads (romeo valve cover bolt pattern). Heads flow 218 cfm intake and 193 cfm exhaust. Intake valve is 1.78" and exhaust valve is 1.452". Bronze guides. 46 cc combustion chambers. 0.600" lift springs. 5 angle valve job. Stainless Steel Valves. Will fit any 4.6 or 5.4 modular block with romeo valve covers.
Cams are XE268H Comp Cams Stage II grinds. Duration is 230 intake and 236 exhaust. Good lope and very streetable for a daily driver.
http://www.summitracing.com/parts/cca-102200/overview/
Located in Cincinnati, OH
Heads: $850 plus shipping
Cams: $450 plus shipping
Also have some extra parts listed below if you need them.
Rockers and lash adjusters (used): $35 shipped
Cam gears (used): $35 shipped
Crank timing gears (2 piece, used, needs thick trigger wheel): $25 shipped
Crank Trigger wheel (thick, used): $15 shipped
New Crank timing gear (1 piece, needs thin trigger wheel): $25 shipped
New Straight chain guides: $25 shipped
New chain tensioners: $45 shipped
