1977 II 2.3 base model lowest of the low fantastic shape tho. Just put in a new battery and cables, new regulator, and had the carburetor professionally restored. After all this, still having the same problem. When the car is dead cold (sat for a day or two) it will start up maybe with an immediate stall, try it a couple of times and it will start running. maybe stall within 5 or 10 minutes. try it again and get it started and drive it around the block a little. after an hour or so try to start it to put it in the garage, if I'm lucky it'll start then stall just when i get it in. Hour or two later try to start it and only get a crank and no start for the rest of the day.
Anyone got any idea what it could be? After doing some research i think it must be the throttle position sensor but i have no idea what it looks like, where it is, or if the car even has one at all.
Please help if you know
Thanks
Thanks
