- Apr 8, 2002
- 58
- 0
- 0
StangSuspension.com is proud to introduce our new upper strut mounts (camber plates) for S197 2005-2008 Mustangs.
StangSuspension Part # SSCCS197
Price - $224.95
Installing new, higher strength strut mounts on your new Mustang will provide a solid mounting point for your front struts, which can improve steering response, front end grip, and road feel. The camber plates also allow you to fully adjust camber easily and accurately.
After you lower your 05-08 Mustang, you may run into negative camber issues (tires leaning inward, inner tire wear). A great way to fix it is with our strut mounts. You can dial the camber right back to OEM specs.
Also, the plates feature an "offset" design which allows you to dial in more aggressive negative camber... for road racing & track use. All you have to do is turn the camber plates around 180 degrees to get more negative camber.
CLICK HERE TO READ MORE ABOUT THE NEW 05-08 STRUT MOUNTS
