Hey guys. I am having an issue where my starter stays engaged after the car starts and I let go of the key. It does not do it all the time and sometimes it will disengage after about 3 secs and sometimes it will keep doing it until I unhook the battery. I have tried unplugging the signal wire from the top post on the starter solenoid on the fender and that does not stop it, only unhooking battery does. I have a mini starter on the car. My question is can I hook the signal wire that goes from the ignition to the top post on the solenoid straight to the signal post on the starter itself?? That will eliminate the solenoid (relay) on the fender itself. I have already installed a new starter and although that seems to have helped it is not gone completely. I have also added a ground wire to one of the starter mounting bolts as well as the solenoid on the fender to make sure they are grounded good. Any suggestions would be awesome but I really want to know what will happen if I hook that signal wire from the ignition to the signal post on the starter??
