As long as you know that wled is the pin your wired to all that needs to be done is to set the port option "wled" to run the fan.....
So to make it clear as mud.....
Wire the fan relay ground to the wled pin.
Go into the programmable input/output menu select the wled port path and input your settings. If in doubt you can hookup a test light and program the output to tps>20 this should let you test the output pin with the gas pedal as a switch (koeo)
