Engine Strange Knock/shake.
Jarrod
Logan, Ohio
Hey guys, first post. I've been having a little problem troubling me with my new '98 GT. She seems to be running a little hard or something. She has a slight vibration while idling in neutral. She also shakes a bit when I shut her off. Any ideas what could be wrong?
Also... I know for sure she has been ran pretty hard by her past owner... Probably has something to do with it. Hopefully not, and it's something I can repair. Lol. Thanks guys.
Sorry for such a late reply @COramprat , it's just enough for me to notice a feel. It sounds like it runs fine. It's throwing a few codes... I'll post them.
Lack of HO2S21 switches - Indicates rich
Evaporative Emission System Control Valve (Low/No flow)
O2 Heater Circuit (Bank 2, Sensor 1)
Lack of HO2S21 switches - Fuel Trim at Limit - Sensor indicates lean
Catalyst system efficiency below threshold bank 1
I haven't yet done a tune-up. I know I should have when I got it, just in case, but I'm skiddish after what happened with my F-150. I'll do one as soon as possible. See if it helps. And how do you run seafoam?
1st and foremost you have a bad catalytic converter. That would cause some of the vibration/rough issues you describe. Do you have emissions testing in your area? If not, go with an off road H or X pipe instead of replacing the cats. I think that would cause the lean and rich codes as well.
I know... Late reply, but I have got the engine to stop jerking while in gear. It was the PCV and hose assymbly. It still does the knocking, but after getting my head out of my ass and asking a ASE-certified Ford mechanic, he said that there is no miss. He said it feels like there is something loose underneath and is hitting the frame. haven't checked it out yet though... One problem at a time. :p
