Suspension Cracking Popping
creek
11
Wichita, Kansas
have a 2011 roush stage 2 with the upgraded brakes and suspension options . getting some bad noise from suspension when first start driving . have heard it a few times in warm weather mainly after it has set for a while , but very noticeable in the cold . I know the abs can make some noise as it adjusts when first start rolling but this sounds pretty bad . after applying brake a few times it stops . has anyone else had this problem ? also have heard some noise from rear when I hit small bumps is this normal for the roush upgrade ?
Hello creek,
Welcome to the forum! You should contact Roush at 1-800-597-6874. You can also find an authorized dealer here.
Deysha
The Neoprene contracts in cold weather and will stick a bit until it warms up and can make some noise. Once it's warmed up it's usually fine. If it is happening during the summer, something else may be wrong.
