Tdc Question
deathb4dismount
Crap, didn’t realize my crotch was in that picture
1,031
530
164
THE BUCKET
When the compression stroke starts at #1 how far off tdc should be showing on the balancer. I am not even hitting the hash marks when compression stroke starts
Edit: Disregard, I am a moron. Mods can close this thread.
To hit tdc your balancer should be at 0 deg. Initial start up timing should be at 10deg btdc are you using aftermarket balancer? If stock balancer did you put the key back in crank hub? Did you do tear down or just replacing? Upgrading?
I'm not sure what you need that information for, When the piston is at it's highest point on the compression stroke it will be at TDC and this is when your pointer should coincide with the TDC marking on your balancer
Reactions: 1 user
