Tech Help! Very Rough Idle At Low Rpm...why? - Carb Guys
Edbert
3,548
32
109
Austin TX
Brand new engine with about an hour of total run time on it, it is a mildly bored 351W which should be a 357 now. Bottom line it runs like crap (to the point of dying) below 1,000 RPM, I'd call it rough between 1,200 and 1,500, and only smooths out at 1,600 and above.
I know my cam is to blame to a large degree. I fully intended to have a much higher than stock idle speed, but not like this, I can live with 1,000-1,200. Cam specs are
Duration: 280I 290E (228I 236E @ 0.050)
Lift: 0.506I 0.506E
Overlap: 110​
I have about a 10.5:1 compression, Edelbrock performer RPM heads and same (dual plane) intake, a single Holley 750 single with vac secondaries, and a 2,800RPM TC.
I suspect the timing is very close to being "perfect", I say that based upon using a vaccum gauge while turning the dizzy. It is definitely running rich, I say that based upon the smell and the blackish smoke I get when roming on the throttle.
I'm simply out of ideas regarding possible causes of the poor idle, I hope there's still a bunch of serious gurus here that know the tricks of the SBF.
First off, thanks for the reply.
I suspected a vacuum leak too but am at a loss as to where. I have the power booster running off the only manifold port I have. By the way the booster holds a vacuum for at least 10 minutes after engine shut off, so I'm sure that is not leaking. The port at the base (rear) of the carb is plugged for now, will hook up the PCV to it eventually. That only leaves the line from the carb to the spark advance unless you think there could be a leak inside the cvarb. It is brand new too, but it did sit (without fuel in it) for about 5 years.
How can it flood at idle without the pumper? I'm going to mess with the idler screws some this Sunday, my week and Saturday are shot. I'm thinking turn them in until it chokes down then back 'em out 1/4 turn and see if that helps. I confess I've not tuned a carb in about 20 years, been driving EFI cars with computer management far too long...LOL.
As the thing sputters at low RPM and I blip the throttle to keep her alive to do get some minor backfiring through the carb.
If it is a true ‘backfire thru the carb and not just a sputter then your timing is advanced too much, Valves are adjusted improperly, valve sticking (intake), cam one tooth out of time?
Could be a vacuum leak at the base of the carb or a crack in a vacuum hose or vacuum cap/plug. To check for leak at the base you can spray carb cleaner around the base of the carb while running. If there is a leak it will change rpm when you hit the area that’s leaking.
By flooding I mean running way too rich – too much fuel for the amount of air taken in. This can have a couple of causes. Stuck or misadjusted float, Choke set improperly, excessive fuel pressure.
The fact that you smell fuel and are getting black smoke is why I went there and you are probably not burning off that excess fuel so its also carbon fouling your plugs as well. Id pull them and see how they look and they’ll probably be black.
Do you have electronic ignition with a strong coil or stock setup?
I would start by backing your timing off (retard) a few degrees till you get rid of that backfire. If that doesn’t go away then you have other problems.
Then I would turn your mixture screws in all the way and back out 1 full turn and go from there.
Check the choke adjustment and operation.
If the carb has been sitting that long and it had fuel in it, the idle circuits are probably plugged .The carb is probably a lot of the problem .The carb base gasket could be leaking as well Those thin gaskets do not seal well and you may need the thicker Fell Pro gasket.
Reactions: 1 user
If you are sure you have no vacuum leaks I would do the following:
Disassemble the carb and make sure it is clean and all passages are clear. Set the transfer slot exposure such that .020"-.040" of slot is showing under the butterfly. The slot will look like a little square when you are done. You also need to make sure that the secondary butterflies are closed at idle. The carb is likely rich because it is idling on the tslot instead of on the idle discharge hole which is also why the idle is so high. Set the idle mixture screws 1-1/2 turns out. Reinstall the carb.
Start the engine and set the initial timing using a timing light. Don't guess based on vacuum readings. For that cam I would set the initial to between 12 and 16 degrees. Once you have the initial timing set you can set the idle speed and dial in the idle mixture setting using a vacuum gauge. I like to adjust the mixture screws to highest vacuum and then turn them out (richer) 1/8-1/4 of a turn. Reset the idle speed if necessary.
Setting the timing with a vacuum gauge can lead to timing that's to far advanced. I'd put a light on it to verify. If it's blowing black smoke as you hit the accelerator I'd think the accelerator pump needs adjusting....
Sent from my SM-N910V using Tapatalk
Is the distributor vacuum advance? Check the diaphragm. Also make sure it is hooked up to manifold vacuum. I prefer mine to be hooked up that way. Much easier for me to get the idle satisfactory for me. You will have to re time it. Also check the foat level.
Sent from my SM-J700T using Tapatalk
If you've backfired through the carb the power valve has probably been damaged. Guessing the carb is older than 1988 you will need to install a check valve to prevent blowing the power valve again if not already installed.
