I just noticed I made mention of "we" several times in the post, not sure why. The only other being in the garage was my dog and she's about as useful as you'd expect. Need to train her to get beers.
The merge can be made w/o the kerfs. When I need to shrink a piece of tubing to choke it down to a smaller neck size, I'll just get a crescent wrench and nibble little inward bends while working my way around the tube. I start out w/ a small bite, and as I get around to the start point, find that I have reduced the OD dramatically in just that one pass. If it needs a second go around, then I do it. but,..
I'd use your existing merge and be done with it. I might try to tack the thing in a few places and beat it to conform a little, but whose gonna see that anyway? And,...You'll more than likely end up wrapping that anyway......so....use it.
See,.....not one wise crack.
I'd just mill it after welding, but then again I have access to a mill whenever I want....and be wary of welding that tube to the T4 flange,.....It'll warp like a btch. Best to bolt that to the turbo when you weld it for real.
I was being serious, this is how it was explained to me by a pipe fitter welding flanges.Wrap a coil of ground wire in a circle on the table around your work piece. Be sure the current flows opposite the direction you are welding. This is the only sure fire way to keep warping to a minimum. For extra insurance turn the bill of your welding cap the opposite direction as well..
Like what?Changing coyote brakes requires special tools. Not happy right now.
Like what?
Do more stuff.............
He's out on a fishing trip getting liquored up. I wouldn't count on too much progress this weekend, lol.
Work will continue tomorrow. I'm in the fetal position for now. For those of you saltwater anglers, this 47" Cobia was caught in San Antonio bay in 12" of water on a soft plastic. Insane.
