Curious if I got enough mods now to finally maybe see a gain out of changing my intake manifold? Thoughts or recommendations for my set up? Car is currently a full bolt on gt on a 75 wet shot. I'm really more so of looking as to what to do next other than build the bottom end at this time. Its getting a new transmission this fall so not worried about that either. Here's my current mod list just to get some ideas of what to do next.
BBK CAI-
TrickFlow 75mm Tb and plenum
Steeda U/d Pulleys
Mac long tubes
Lethal performance o/r X pipe
Mil Eliminators and Extensions
magnaflow 2.5" catback
sct tuner
Bullet custom grind cams
Brian Tooley racing valve springs and valve seals
excedy stage 2 clutch
excedy lightened flywheel
ford racing throw out and pilot bearing
Maximum MotorSports Caster Camber plates
H and R super sport springs
Tokico Front struts and Rear Shocks
31 spline moser axles
ford 31 spline trac lock
Upr Differential Cover
4.10 gears
Sve drag wheels 15x7 and 15x10 on nitto 555r Drag radials
drive shaft loop
Upr 340lph Fuel Pump
Pertronix coils
Auto meter A/f ratio wideband
75 shot Zex wet n20 kit
nitrous outlet bottle heater
Zex dual outlet purge kit
Zex Nitrous bottle Pressure gauge
Zex Blow Down tube
Slp line lock
Upr rear control arms with Spherical Bearings
Welded in sfc's
Rear Seat Delete
Window tint
Pioneer radio with aux cable
Mach 1 Chin Spoiler
Raxion Halo Headlights
BBK CAI-
Steeda U/d Pulleys
Mac long tubes
sct tuner
4.10 gears
drive shaft loop
Pertronix coils
Zex Blow Down tube
Slp line lock
Welded in sfc's
Rear Seat Delete
Window tint
Mach 1 Chin Spoiler
