Expired Turbo Hot And Cold Side Top End Engine 8.2
Changing combinations I am selling single turbo hot and cold side (no turbo or waste gate ) and top end components with E85 tune for SBF 8.2 deck includes
Hot side side turbo mounts side ways on pass side ( no turbo or waster gate)
Cold side 3 inch dia starts on pass side enters engine on driver side throttle body has a V band clamp
Precision turbo air to air intercooler
Edelbrock proformer heads ported 202 intake valves
Edelbrock Victor EFI upper and lower intake mild port work
1 inch phenolic intake spacer
Crane energizer pedestal 1.7 rockers
Professional products 75MM throttle body with spacer and welded V band
Comp cams turbo spec cam. Car was tuned with
Professional fuel rails
C&L 76MM mass air meter welded to V band goes to throttle body
Diablo Mafia air flow calibrator was tuned on
Aeromotive pro series eliminater fuel pump
A9L computer with chip tuned for this set up
80 pound injectors
All these components were tuned together on E85
All parts are still on the car. This is a kit you can just bolt on and go drive. Please email, call, or text with any question or any info needed 219 455 3527 Thanks
