well its not the uberest cheap mod evah, but it's good none the less... ever wondered if your opening your tb all the way when you floor it thanks to all the slack in the throtle cable? Tired of not being able to do heel-toe driving especially while auto-xing and the gas pedal being up to 6 inches behind the brake pedal making everyday stop and go driving a pain in the ass... well i got all the solution for all of you's! and it only cost like $0.30
first you gather 2-3 of these depending on what level you want the pedel
lean your seat back so you can get under the dash as seen here
take your kicks of in order to not get durt on your uber exspensive seats and position yourself in this manor as illustrated by this limited eidition mark meguire bear...
now i don't have nay pics of this party cus i'm 6 1" and it's a bitch to get down there but... you start the loop on the zip ties then pull the pedal foward and put the ties around the cable at the very top of the pedal underneath the dash and tighted them down as far as they go use eithe 2-3 at this point depending on how high you wants the pedal to be... then cut the excess zip tie i used one of these handy dandy things
and now your pedal will be all nice and high up next to your brake pedal and now you can push the gas pedal untill it stops and be garenteed that the throttle body is all the way open and you can have all sorts of fun heel-toe drivng and prolly even imporve your times at the auto-x track hope this works for...
