The vibration has nothing to do with speed of the car, cause it will do it while free revving). Comes in at about 1500 rpm then kinda goes away till 2000 rpm and it doesn't seem to be super consistent as to how much it vibrates. Its not a SUPER bad vibration but it does make the steering wheel vibrate a tiny bit... Had someone feel the top of the motor while i revved it to about 2000 rpm and they said it didn't really feel like it was vibrating.
Ive checked the timing and its right at 10 degrees like we set it after HCI. Balancer is only maybe 1 year old and looks fine (and the correct timing makes me think its not that)...
Motor mounts maybe? Flywheel bolts? (even though i KNOW we torqued them correctly, and it went on correctly). The vibration really seemed to be noticeable AFTER the trans mount.
Any suggestions on what this may be, as i don't know if its a problem or just a characteristic of the poly (i know its definitely stiffer).
Thanks for the help,
David
David
