I'm posting this for a friend of mine since he is having issues posting...
Were is it going? why does it come up low after runing the car.
Hey guy's need some help with this one. Ok my coolant run's low on my radiator after I drive the car around. I have a Auto Meter mechanical gauge in the car.
I have a new ford racing 2-row aluminum radiator.Radiator & Heater Hoses are new hose clamps are all on tight and check by a friend.
New napa 180 Thermostats with gaskit both bolt's are on tight also check by a friend.Thermostat housing is not creck at all no leak's. Heater core was done at a ford dealer a few year's ago. Water pump was replaced a year a ago work's fine.
I have test the coolant tank by fill it up with water and let it sit and i mark were the water was. Came back a day later still in the same spot were my mark was made at. I have new radiator cap from napa on. Fan clutch i have test i let the car set at idle for 30 mintes car does move above 190.
I have a pressure test the coolant system at 16psi and it does fill,
i also test the cap it pass that too.
Car run's great too. no smoke at all from the catback, the gauge all way's reads at 180 - 190 degrees. One night at the beach (it was cold ouside 60 or 65 so) i had to stop drive the car because the temp said 210-220 if i give it gas it wood go up fast. i try to turn on the heat it did not blow hot air it was cold.
got home the next moring took the cap off radiator had coolent at the top.
I have look at the oil stick clean no water mix with the oil. Also i did a oil change about mouth and the oil just look like old does.
not to sure were the coolent is going? and not to sure what to do next. please help.
