will 17x9 rims fit 235 tires? Or will i need 245 or higher? I have a 66 and i've heard the largest tires that'll fit are 245s if your lucky. I'm talking about not cutting out the wheel wells or modifying anything...thats too hard.
Even if the rim is only 2" wide? LOLThe smallest tire you can fit on a 17" is a 245 I believe.
dodgestang said:17x9 is generally accepted to be too wide to fit on the car
Is 17 x8 with 4.75 backspace the best rim for running on 66 coup even if I'm running 225 45 17s I will be doing Shelby drop but was wondering how much rubbing 225 45 s will have bone stock I'm going with the 225 45 17 s all around for several reasons highest being I found a deal on that size VOGUE high performance 60000 mile warranty tires 77 bucks each I'm also buying B and G rod works old school gunmetal 17x8 rims with 4.75 backspace or I can get 17x8 s with 4.5 backspace and wondering if I am correct in thinking 4.5 would stick a quarter inch further out ?Did you all forget my chart!!!!!
Sheesh I get a job and can't post during the day anymore and what happens....you all forget me.
HIt up the super duper modified tire and wheel chart on my site:
Mustang Photo Archive
In a nut shell:
Rear: 235 45 17 no mods needed.
Rear: 245 45 17 sometimes you need to roll the fender depending on a lot of factors
Rear: 255 40 17 with fender rolled
Front: 215 45 17 no mods needed if bone stock on the front end
Front: 235 45 17 no mods to fender needed if you have the shleby drop
All tire sizes qouted for a 17x8 4.75bs wheel.
