I have rust on my 95 GT lower shock tower and frame rail. LMR makes replacements but they are for foxbodies, I hear that the sn95 and fox chassis at very similar, will a front frame rail piece right behind the wheel fit?
I'm going to guess no -- if it fit they'd probably list it for your year, but you could ask LMR for a better answer. You'd probably be better off having the pieces you need cut from a donor car than trying to get the Fox pieces to fit. Either way that kind of work is labor-intensive and will require a lot of fabrication, so fit / doesn't fit isn't super meaningful (this won't exactly be a bolt-on).
