look behind each headlight and there's a wire harness going to it...there's 2 clips that holds that harness onto the back of the headlight...use a small screwdriver to pry up on the clips to release the harnes...then just unscrew the retaining ring on the back of the headlight counterclockwise and the bulb should come right out...be careful not to touch the glass on the new bulbs since that may cause them overheat from the oil on your skin...then just place the new bulb in the back of the headlight, screw the retaining ring back on, and plug the harness back in...should take about 10 minutes to do both lights...
