Hi,
I have a 97 Cobra and the starter has been intermittent. The battery is good, I replaced the positive and negative battery terminals and made sure the ground cable to the block was good. The ignition switch is good, the anti-theft is good, clutch switch is good, and power is getting to the small relay in the distribution box every time the key is turned. I haven't gotten to the starter/solenoid under the car yet.
My question is this: What have others with this same problem had to replace? Is it most likely the solenoid, starter, positive battery cable, or small relay? Just curious, need input.
Thanks in advance for replies, Steve
