- Sep 4, 2011
- 0
- 0
- 0
2006 Ford Mustang GT D.S.S. 5.0L Stroker Crate Engine Street Legal Race Car
Located in Southern California
Exterior: Performance White Clearcoat
Interior: Dark Charcoal Leather
Miles: 21,XXX
Included with “Order Code 140A-Prem GT Coupe”
-Driver & Passenger Air Bags
-Rear Window Defroster
-Anti-Lock Brakes
-Traction Control
-Power Driver’s Seat
Optional Equipment
-Interior Upgrade Package
-Satin Aluminum Panel
-Active Anti-Theft System
MODIFICATIONS
Engine
D.S.S. 5.0L Stroker Crate Engine (400HP, 4k miles on it) $11,770 w/dealer discount
-SUPER MODular Max Quench 3V: 5.0 Stroker Balanced to racing tolerances and blueprinted, forged DSS Pro-X Series 3V Pistons, assembled in a Level 10 pace prepped ’05 aluminum block with the billet aluminum Main Support System installed with custom ARP main studs.
-SPECS: Block: Level 10 Race Prepped Block – deck equalized and squared, deck plate bored and honed in CV616 with sub 10 micron filtered man-845 honing oil, and numerous other Race Prepped operations, RODS: 4340 Forged 5.850” Full Floating H-Beams with ARP 2000 bolts, CRANK: Forged 3.75” stroke, PISTONS: Forged Pro-X #4730 (Max Quench, -9cc), RINGS: Moly E-916K, ROD BEARINGS: Tri-Metal CB-745P, MAIN BEARINGS: Severe Duty Tri-Metal 149M
-SOHC 3V longblock: 4.6/5.4L 3V SOHC longblock Assembled with SOHC 3V heads, rockers, lifters, oil pump, head bolts, etc. Heads torque with stock cams and timing chains installed.
-CNC Full Port 3V: CNC port job on 3V cylinder heads with CNC finished intake and exhaust ports and chambers
COMP CAMS Camshaft $
SCT Xcalibrator2 $350
HT2 Spark Plugs w/install $100
STEEDA Charge-Motion Control Plates $300
STEEDA Underdrive Pulley System $200
Granatelli Motorsports , Inc. Dyno $500
Granatelli Motorsports Hot Coils $
Marcy Motorsport Engine Dyno and Tune $300
Mustang GT Billet Throttle Body $560
STEEDA Cold Air Kit $271
STEEDA Intake Spacer $91
Diablosport-Steeda Predator Tuner $360
SCT Excalibur 2 Tuner $
Auto Meter Ultra-Lite II Tachometer $230
HAWAII Racing Valve Cover Set $270
Borla Long Tube Headers
Borla X-Pipe Assembly
Borla Stinger High Flow Metal Catalytic Converter $483
-OEM cats included for smog purposes
Stainless Steel Hydraulic Clutch Line $100
Performance Hydraulic T/O Bearing Retainer $120
HiPo Hydraulic Throwout Bearing $276
STEEDA Billet Oil Cap Cover $50
MGW LTD Dipstick GT $28
Lightweight Radiator Bracket $
Transmission/Driveshaft/Axle
STEEDA Tri-Ax Shifter $
STEEDA Shifter Isolator Kit $
HAWAII Racing Aluminum Flywheel $319
HAWAII Racing Flywheel Bolt Kit $44
Hoek’d Up Performance Multi Disk Clutch $400
R.P.S. High Performance Carbon Fiber Clutch $1,700+
Coast Driveline & Gear 8.8 Posi-Traction 31T Rear Differential $420
Coast Driveline & Gear Aluminum Driveline $
Suspension/Wheels/Tires/Brakes
STEEDA X5 Balljoint kit $150
STEEDA Double Bar Strut Tower Brace $125
STEEDA Adjustable Panhard Bar $140
STEEDA H.D. Panhard Bar Brace $68
STEEDA Front Swaybar Race Endlink Kit $
STEEDA S197 Mustang Competition Upper Adjustable Trailing Arm/3 Link $
Bumpsteer Kit $
Street Race Lower Trailing Arms $
Rear Sway Bar Chassis w/Links $
KW Suspensions Coilover V3 $1,825
Billet Camber Adjusters $
STEEDA 18 x 9.5” Ultra-Lite SATIN Wheels + Powdercoat $1320
KONIG 18x9 Beyond Ultra Lightweight Wheels $
275/40/18 Nitto 01 $1220
275/40/18 Kumho MX $908
Wilwood Engineering Complete Front and Rear Set Up $4,000
-Superlite 6 Big Brake Front Hat Kit Pro Street App with 13.06” Diameter Vented Rotor
-Dynalite Pro Series Rear Parking Brake Kit with 12.19” Diameter Vented Rotor
Hoek’d Up Performance MC Brake Duct Kit $300
Exterior
Mustang Bullitt Replacement Grille $200
Hoek’d Up Performance Jack Rail System $236
Safety Tow Hook $225
STEEDA Mustang Rear Brake Light Decal $20
STEEDA Silver Billet Fuel Door GT Logo $139
STEEDA Hood Pin Set, Captive Latch Type Stainless Steel $22
Mustang Shelby GT500 Rear Wing by Ford Racing $230
Cowl Hood $
California Car Cover Co. Premium Luxury Car Cover $300
Interior
Ross Mustang Custom Spec Roll Cage $1,200
Sparco Evo L and XL black seat $1,460
Sparco Seat Side Mount Base Kit Black $69
Sparco Seat Track Set $59
Mustang Seat Base Passenger 500 series $135
Simpson Racing 55” Seat Belt F/M Polyester $150
Simpson Racing Camlock Individual Harness F/M Polyester $85
Simpson Racing Dual Anti Sub Belt B/I, Polyester $24
Simpson Nomex Harness Pads $76
Modular Mustang Racing Rear Seat Delete Kit $140
MGW LTD Power Outlet Plug SA/GT $23
MGW LTD Gripper Knob SA/GT $52
Battery Relocate kit behind passenger seat $
Optima Red Top Battery $
SELLER’S NOTES
The Build Sheet speaks for itself. Officially known as a BDX Mustang, this car was built to handle like it is on rails and was raced against the likes of Porsche GT2s, GT3s, EVOs, STIs, etc. in the Redline Time Attack Series and against racers such as Tanner Foust. BDX Mustangs were raced by NASCAR driver Chris Cook among other racers and took first in the Street Class RWD.
This is a one-of-a-kind car that looks great, sounds great, and drives great. Listed above are the parts and prices I have the information for—remember that labor, tax, and shipping is not included in the majority of it. If I had not hurt my back recently I would be keeping this forever as my Autocross, Track Day, and Sunday Driver. With my lower back issues I am getting out of performance driving. Again, this car is set up for racing, it has a race clutch and is not for those who can’t drive stick or have a weak left leg. This car comes along with receipts and documentation as well magazine articles and memorabilia this car was featured in. No deadbeats, tire-kickers or low-ballers please.
Miles: 21,XXX
-Anti-Lock Brakes
-Traction Control
Optional Equipment
MODIFICATIONS
Engine
Bumpsteer Kit $
Exterior
Cowl Hood $
Interior
SELLER’S NOTES
