Mustang 1987 T-TOP need name of the part or where to buy?
Marti
Houston
Hello i been looking for this part that meets with the body to the t tops. I don't know what its called, but i sent pictures to further explain
It’s part of the t top trim. It’s specific to the 87-88 models so your only option is to find a part out.
The front MIGHT be the same as the 86 down but the rear is for sure different
^This^
Go to LMR.com and check out their t-top restoration parts. T-top assemblies and weatherstrip went through at least 3 design iterations, so you'll want to make sure you're getting parts for the right year.
No no no , it’s separate . There’s trim and there weatherstrip
Sounds like he's looking for the trim, not the weatherstrip. What year is the car? Need to know to find the correct trim.
Up through '86, the front and rear trims are one piece. On the '87 and '88s, the front and rear trims are three piece. I grabbed two sets of trims from the older cars hoping to get rid of the joint in the middle on my '87 and they don't work. The older ones are also shorter due to the different side trim on the car.
Thanks. Was not sure on that one.
