Bottom end!
Bottom end!
Bottom end, just the crank. no pistons
Turbo 2.3 short block all lubed up and assembled
Mhale rod bearings Hastings piston ring kit Federal Mogul main bearings Fel-Pro USA gaskets
Fuel pump block off plate
I made a custom gasket for this bad mama jama! and prepped it for paint... i got carried away
Fun fact!
Fun fact!
Ford 2.3 oil pick up tubes make great beer tables!
Bottom end!
Bottom end!
Mhale rod bearings Hastings piston ring kit Federal Mogul main bearings Melling's M86E oil pump (make sure you buy the one that includes the pick up tube gasket) Fel-Pro USA Oil Pan Gasket
Cylinder/ piston 1
Cylinder/ piston 1
TONS of carbon build up, still some original crosshatching from either last re build or original manufacturing, looks as if ran rich and burnt oil
Cylinder/piston 4
Cylinder/piston 4
Cylinder/piston 3
Cylinder/piston 3
Cylinder/piston 3
Cylinder/piston 3
Original cylinder Head  different angle
YUCK, exhaust valves look beat to hell, cracks on exhaust seats on chambers 2 and 3 other possible reason for car being junked possibly caused by overheating and or clogged head gasket
2.3 Block, slightly different angle
2.3 turbo motor, cylinders 1-2 leaking into each other as well as 2,3 3,4 possible cause of car being junked was.... blown/ leaking head gasket
Piranahbite
Williams 2.3 Turbo build
1988 Ford Thunderbird 2.3 Turbo Engine Rebuild/Upgrade
What an awesome community!
Album information
Album owner
Piranahbite
Date created
Item count
11
View count
67
Comment count
Rating
0.00 star(s) 0 ratings
Album privacy
Piranahbite
Can view media items
Everyone
Can add media items
Album owner only
