Get more information on the this Mustang performance throttle body here: http://www.latemodelrestoration.com/item/SVE-TB1501K/SVE-70mm-Throttle-Body-And-EGR-Spacer-50L-Mustang-86-93
Upgrade your puny factory throttle body with a SVE 70mm throttle body kit that includes the TB, correct EGR spacer and all needed gaskets. Not only will it give you a boost in performance but it will also improve the under hood appearance with its polished finish. Watch the video as Jmac shows you how to install a new performance throttle body on your Fox Body Mustang.
Part Number# SVE-TB1501K
Fits: Ford Mustang 5.0L GT LX
Fits the following years: 1986 (86) - 1987 (87) - 1988 (88) - 1989 (89) - 1990 (90) - 1991 (91) - 1992 (92) - 1993 (93)
SVE Throttle Body & EGR Spacer Kit
This 1986-1993 Mustang SVE 70mm throttle body and spacer kit is perfect for adding horsepower and torque to your 5.0L motor. By increasing the size of your throttle body and EGR spacer, you get more air flowing into your motor which gives you increased performance! Pick up this kit today and get your Foxbody outrunning the competition.
SVE 70mm Throttle Body
This 1986-1993 Mustang SVE throttle body is a great way to bring in more air for more power on your 5.0L motor. This throttle body has an opening of 70mm, a huge increase from the 55mm that came stock on these motors. This allows you to bring in as much air as possible to help maximize your performance. Pair it up with a cold air intake and a new intake manifold for serious horsepower gains!
SVE 70mm EGR Spacer
This is an SVE 70MM EGR spacer for your 1986-1993 Mustang 5.0L. This spacer is needed when replacing your throttle body to ensure proper flow through the throttle body to the intake manifold. It also has coolant line provisions that help in heating your air charge temperature. Includes the EGR gasket and spacer-to-intake gasket.
Media information
Category
Mustang Technical Videos
Added by
Jarrod@latemodel
Date added
View count
2,690
Comment count
Rating
0.00 star(s) 0 ratings
Share this media
