• Community Forums
  • Regional Forums and Event Information
'03 Cobra
  • Thread starter Thread starter Rootus
  • Start date Start date Apr 10, 2004
  • 4
  • 5
  • 6
First Prev 6 of 6
Darkness
3,345
Banbury - England
Apr 13, 2004
#101
  • Apr 13, 2004
  • #101
HairyCanary said:
Peak power ain't great, but the AFR's are making decent power under the curve in any case. I've only run on street tires, spinning through 1st & 2nd. My torque curve combined with 3.73's makes for a very squirrely launch on street tires. With traction I hope to add two or three mph to my traps, and hopefully get this pig solidly into the 12's. And maybe I'll let someone with the skillz (Chris) see what he can get out of it...
Dave
Shame you couldnt use my DR's that one time, it would've at the very least prevent 2nd gear spin. If you're going one of these days let me know if you want them
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 13, 2004
#102
  • Apr 13, 2004
  • #102
duner said:
You didn't like my other suggestion?
I thought maybe if I ignored it, then it would just go away...
SVTdriver
3,319
Seattle Wa
Apr 13, 2004
#103
  • Apr 13, 2004
  • #103
HairyCanary said:
Hey, how about this.
Drop these into my car:
http://www.stangparts.com/products/partpic.cfm?TypeID=5&ID=4013&Page=1&ShowSpecials=FALSE
.. and ..
http://www.stangparts.com/products/partpic.cfm?TypeID=3&ID=3713&Page=5&ShowSpecials=FALSE
And skip the turbo...
That would get you the 03 cobra without changing your bodystyle.
Visceral
790
Portland, OR
Apr 13, 2004
#104
  • Apr 13, 2004
  • #104
Toddzilla said:
I do agree that you should maybe try to sort your combo out further.
I don't think that you should go to the A9L as that IS a downgrade.
See... you guys are thinking in the wrong terms...
Its not necessarily a downgrade, but it sure is simplifying things alot.
Now I admit that 03 Cobra engine would be really bizzarely cool sitting in a 93 Fox notch...
"Yeah, its still a stock longblock car."
chris
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 13, 2004
#105
  • Apr 13, 2004
  • #105
Bah. The A9L is not simpler than the 94/95 EEC. Just $400 more... And I can tell you my cam specs, so swapping in another cam seems overkill. Now, swapping valve springs sounds fun, but only if I get to use the Comp Cams beehive springs...
Visceral
790
Portland, OR
Apr 13, 2004
#106
  • Apr 13, 2004
  • #106
HairyCanary said:
I'm pretty sure the problem has something to do with how the cam is degreed. There's not a lot of other good explanation for why the torque curve is so skewed to the bottom end.
There are a few, but they are long-shots. Like bad valvetrain geometry, falling down lifters, a single spring not taking it at 4500 or so rpm, a cam thats much smaller than expected, some odd airflow impediment... Its about sorting out the valvetrain and the airflow path...
I have nothing over anyone else other than alot of practice in my car and a willingness to flog the living $h|+ out of it. Thats not to say I wouldnt take a shot at it. Last time I tried an SN95 on the drag strip it was a Saleen S281. I improved his time over 1 second! 15.9 to 14.8 or so
chris
Visceral
790
Portland, OR
Apr 13, 2004
#107
  • Apr 13, 2004
  • #107
CC918s are actually really cool....After I get my 12s Im boing to do rockers, springs, and the intake. Im going to do 918s if I can (I dont know the valvespring seat diameter specifics). I have a really sweet valve spring compressor too
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 13, 2004
#108
  • Apr 13, 2004
  • #108
Okay, we talkin 'bout the same spring. Why 26918 instead of 26915? My current springs are 135# on seat, but I hear that with the beehive springs you don't need to run as high of a seat pressure to get the same result.
http://www.compcams.com/information/WhatsNew/Press/26915_26918.pdf
Toddzilla
Banned
Aug 14, 2001
386
Edmonds, WA
Apr 13, 2004
#109
  • Apr 13, 2004
  • #109
What does Ed say about your springs?
Also, why not get that AF fixed? It can't be helping.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 13, 2004
#110
  • Apr 13, 2004
  • #110
I asked Ed for advice, and he suggested replacing the MAF with an 80mm (currently it's 75mm) and the throttle body with a 75mm (currently 65mm). I'm no longer asking his advice.
As for A/F, it could use a little more fuel, especially on the bottom, but I'm guessing the 1/2 pt won't make a huge difference in power, maybe as much as 5.
Dave
ddonaca351
2,055
Camas Washington
Apr 14, 2004
#111
  • Apr 14, 2004
  • #111
You would want the X3Z burn for your motor anyhow..... the breakpoint vs batt volts would be wrong on the A9family (L/P/M)
But then you already knew this....
DD
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 14, 2004
#112
  • Apr 14, 2004
  • #112
DD
Gawd, wouldn't that be funny -- take my nicely tuned T4M0 (which is TwEECed to a modded J4J1) and use a PIH kit to make it into an A9L, and then use the TwEECer to modify *that* into an X3Z...
Dave
  • 4
  • 5
  • 6
First Prev 6 of 6
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
W
03 cobra shifter question
  • Wtupribs
  • Sep 7, 2025
  • SVT Tech Forum
SVT Tech Forum Sep 8, 2025
Wtupribs
W
For Sale 1993 Mustang SVT Cobra - Black - 5 Speed - 88k Miles - Single Owner
  • Buddy Jake
  • Jun 16, 2026
Fox Body Mustangs For Sale (1979-93) Jun 20, 2026
Habu135
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 1, 2026
limp
J
Cobra 289 motor & parts
  • James Werstiuk
  • May 20, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 20, 2026
  • Community Forums
