SOLD 1989 Turbo Mustang Gt, 700+rwhp Dynoed, 1000+rwhp Ready, Street/strip
RyanSG
286
35
Allentown, Pa
www.sloppymechanic.com
I’m selling my 1989 Mustang. The odometer reading is 90658, but pretty much everything has been replaced in the last 5-8000 miles anyway suspension and driveline wise anyway. Here is the list of what has been done to the car just to cover all the bases. I drove the car around many a time so it’s definitely a street/strip car, no overheating issues in traffic etc. Turn the key and go with 93 pump gas all day long. Car is currently on 10psi which is roughly 550rwhp but can be turned up to about 16 on pump gas which made about 670rwhp. On race gas we called it quits at 719rwhp at 18psi and a soft tune to be safe in case we ran out of fuel pump (have video). The combination is ready for 1000rwhp without issue with a larger fuel pump and injectors. Car ran 10.28 at 138mph on 10psi first time out off the foot brake (have slip). So it’s an easy 9 second car.
If you have any other questions feel free to ask but the car was done right. Just needs some paint and it’ll be a killer street car to cruse with
or run 9’s in all day long. Also ready in January for Antique plates if you want.
Call/Text/E-mail. 610-349-6908
Asking Price $15,500
Suspension:
· Front has Lakewood 90/10 shocks, rear has Lakewood 50/50 shocks.
· Moroso Trick Front drag springs. Stock mustang springs in the rear
· New Wheel bearings about 10000 Miles ago along with Slotted/Cross Drilled rotors installed.
· Rear suspension is all Team Z, adjustable uppers, adjustable lowers, and anti-roll bar.
Rear Diff:
· Detroit Tru-Trac unit (3 helical gear version)
· Currently has 2.73’s in it but I’m also giving a set of 3.27’s with the car.
· Replaced all bearings in the rear.
· Alloy USA 31 spline hardened axles.
· 3” Moser hardened studs.
Transmission:
· Dynamic transmission TH400 with conversion SFI bell housing.
· 1st and 2nd gear decel bands removed for larger clutches.
· Trans brake with button on steering wheel.
· Reverse pattern full manual valve body.
· Stronger driveshaft and u-joints.
· Front mounted trans cooler.
· Trans brake is also connected to the 2-step (can be on or off in the ECU). I have a safety switch on the T-brake so with the switch in the off position it can just be used for the 2-step, or in the on position 2-step and T-brake). Full boost no problem off the line!
Chassis/Inside:
· Power windows and door locks (all working).
· Weld in Sub-Frame connectors + bolted to seat brackets on both seats.
· Drive shaft loop.
· “Battle box” torque box reinforcement plates.
· 8-Point roll cage, also welded to Sub-Frame connectors. Swing out door bars can be removed or just swung out. I have all grade 8 hardware to install the bars and it’s NHRA legal at the track.
· 5 Point harness (NHRA Legal) as well as stock seatbelt.
· Hurst Quarter stick shifter for TH400/Powerglide. Mounted in custom box to fit in original 5 speed location. It does not hit the radio but my other radio died and just never replaced it.
· All speakers are working as well as dash and gauge lights.
· All gauges work, Stock Gauges: Oil Pressure, fuel level, batt voltage, temp.
· Other Gauges, Autometer carbon fiber, Boost/Vac, EGT, Trans Temp. AEM Wideband (tied into ECU as well)
· Originally a 5 speed car and the pedal is still mounted etc (just under carpet) so it can easily be converted back into a manual car if you’d like.
· Hurst Roll Control line lock with safety switch to activate.
· Rear seats removed, Battery is located behind passenger seat in NHRA legal aluminum box, tied into the Sub-Frame connectors as well.
· Power steering.
· Factory A/C car but A/C has been removed.
Engine/Fuel/:
I have all of the short block build info from the engine builder as well that will go with the car. But I’ll give a general run down. It’s very capable of 1300hp and a solid 1000hp to the wheels with no issues. The short block was built to run NMRA.
· Aeromotive A1000 Fuel pump with pre and post filters.
· Sumped stock tank, fuel sending unit still works with the stock gauge.
· -12 feed lines, -6 return.
· Aeromotive Pressure regulator.
· Aeromotive larger fuel rails.
· Siemens Deka 80lb/hr Pencil injectors, 12ohm.
· ARP 2000 Studs and bolts.
· JE Kraft Trick flow twisted wedge cut pistons, -18cc dish with JE wrist pins.
· Eagle 5.400 H-beam rods.
· Ford R-302 Block with painted lifter valley.
· Trick Flow Street upper and lower intake.
· 75mm Throttle body with EGR delete.
· PCV system routed with both valve covers to catch can.
· Ford racing F-303 cam.
· New double roller timing chain (5K ago).
· Trick Flow Twisted Wedge 185CC aluminum heads.
· Com cams upgraded valve springs (unsure of spring pressure but good for plenty of boost.)
· 9:1 Comp ratio, 150PSI in each cylinder with the comp tester.
· Oil filter relocation with racing style larger oil filter.
· 2-core aluminum radiator with dual electric fans (ecu controlled and adjustable)
Turbo Kit:
· Borg Warner S480 Turbo, 80mm compressor, 96mm Turbine with T6, 1.32 AR housing. Anti surge ported, race cover, polished. Good for over 1K to the wheels.
· Quick spool valve set to 3psi. Spools very quickly for such a large turbo.
· All hot and cold sides’ Tig welded, and coated.
· 3” cold side piping with Air to Air intercooler up front.
· 4” downpipe.
· Custom made tubular headers.
Electronics/Ignition:
· AEM 30-1400 EMS stand alone ECU (I’ll give you the tunes and install disk) with Painless wiring EFI harness, stock connectors on everything. The ECU does everything you could imagine.
· AEM EPM unit (crank and cam sensor).
· LS1 style coil packs, 1 for each cylinder.
· AEM Wide band gauge also tied into ECU. O2 correction enabled.
Extras:
· Car will come with Stock hood as well as the fiberglass one on there now.
· Extra set of Weld rims with 28x9x15 Hoosier drags (still good).
· Extra front GT bumper assembly with headlights etc.
· Set of 3.27 rear gears.
  • Sponsors(?)
Thread starter Similar threads Forum Replies Date
8 Engine 1989 turbo mustang Fox 5.0 Mustang Tech 5
madspeed SOLD 1989 Mustang Gt 333 Turbo In Pa Fox Body Mustangs For Sale (1979-93) 7
Lx89Stang05 1989 Mustang Lx TURBO 5spd Lots of Mods....F/S..MASS 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
88mustang on a budget Project "blown Budget" 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
S Electrical wiper problem 1989 LX Fox 5.0 Mustang Tech 10
M Drivetrain Going from T5 to 1996 truck 4r70w 1989 GT Fox 5.0 Mustang Tech 8
C Rebuilding my 1989 mustang GT 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
C What's it Worth? 1989 LX 5.0 Coupe What is it Worth?!?!? 3
MikeR351w 1989 Mustang Carb conversion, need pics. Fox Engine Swaparoo 0
M Please help 1989 GT Hatchback.I can not find an L.E.D.smoked 3rd taillight. The Welcome Wagon 4
J 1989 lx mustang help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
8 General 3g alternator upgrade on 1989 AscMclaren mustang. Special Production 2
1989FoxBro 1989 5.0, Awful squeaking/whining noise because of no PCV System? Fox 5.0 Mustang Tech 12
7 Need 1988-90 lx body parts passenger door and maybe passenger fender ? My paint code is 7n thanks The Welcome Wagon 12
M Brakes Does anyone know specific casting numbers on 1989 GT O.E. Calipers? Fox 5.0 Mustang Tech 11
C For Sale 1989 lx hatch 5000 Fox Body Mustangs For Sale (1979-93) 0
C 1989 mustang GT smoking white Fox 5.0 Mustang Tech 7
BP Builds Fox 1989 LX complete restoration - the long slow project car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
S 1989 Foxbody Project - For Sale Fox Body Mustangs For Sale (1979-93) 0
EarnhartBuilt For Sale 193 Original Miles on this RARE Barn Find 1989 Ford Mustang LX 5.0 Convertible Fox Body Mustangs For Sale (1979-93) 1
G For Sale 1989 5.0 mustang turbocharged Fox Body Mustangs For Sale (1979-93) 3
M 1998 explorer 302 into 1989 car.... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
M New member - Mike - 1989 GT Convertible The Welcome Wagon 3
Y My new ‘89 LX Conv 5.0 The Welcome Wagon 2
L Engine Constant ticking/clicking noise 1989 Mustsng GT Fox 5.0 Mustang Tech 2
Rusty327 1989 Mustang GT convertible Fox 5.0 Mustang Tech 10
G Interior and Upholstery 1987-1989 Coupe rear seats 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
M Does anyone know what the hole to the left of the oil pressure sender is for?? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
K Brake switch 1989 fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
M Low Fuel Pressure 1989 LX 5.0 Fox 5.0 Mustang Tech 14
C Considering rebuilding my 1989 mustang GT 302 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
C Fox Will these rims work on my 1989 mustang? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
8 1989 347 stroker motor starting issue Fox 5.0 Mustang Tech 7
M 1989 Mustang LX 5.0 engine problem Fox 5.0 Mustang Tech 22
stang89bidges SOLD 1989 Mustang GT 5.0 Black, Hatchback, T5, DFW Texas Fox Body Mustangs For Sale (1979-93) 8
C New member with 1989 Mustang Fox 5.0 Mustang Tech 3
J 1989 wont start after motor swap Fox 5.0 Mustang Tech 79
E Fox 1989 GT wiring 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
E 1989 stiff clutch Fox 5.0 Mustang Tech 7
S Engine 1989 mustnag efi to holly sniper swap Fox 5.0 Mustang Tech 19
W 1989 CFD special edition random stall? Fox 5.0 Mustang Tech 10
M 1983 engine going into 1989 mustang lx 2.3L (N/A & Turbo) Tech 4
J Engine 1989 Gt vert stock heads valve spring help Fox 5.0 Mustang Tech 1
T 1989 5.0 GT smoke out tail pipe issue. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
S Engine 1989 mustang gt wont start when reseting the key switch Fox 5.0 Mustang Tech 11
R 1989 Ford Mustang GT Stock all the way Fox 5.0 Mustang Tech 4
C New to Fox body help needed Fox 5.0 Mustang Tech 5
R Electrical 1989 gt 5.0 pops thru intake on hard accell, hot or cold, runs good if easy on throttle ???\ Fox 5.0 Mustang Tech 2
K Fox 1989-looking for the best camshaft 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
R Engine 1989 LX - Engine Trouble Noise & Rich - Help Appreciated Fox 5.0 Mustang Tech 8
