Hello everyone here is my 89 hatch for sale on ebay if anyone is interested. tons of parts. there are more pics on the ebay site.
http://www.ebay.com/itm/Ford-Mustan...a8bae5188&item=251451560328&pt=US_Cars_Trucks
Engine:
-Rebuilt 306
-custom CAM
-Edelbrock Performer RPM heads (ported on rebuild)
-Edelbrock Performer RPM upper intake
-Edelbrock Performer RPM lower intake
-Edelbrock Performer RPM plenum
-Edelbrock 70 mm throttle body
-24lbs injectors
-BBK Mass Air Meter for Cold Air Intake and 24lb Injectors
- BBK V8 Fender well Cold Air Intake
-larger radiator and electric fan
-new PVC valve
-new performance wires and plugs
-Edelbrock Fuel Pump - 255LPH
Suspension:
- Maximum Motorsports weld in subframe connectors
-AJE Racing Tubular Control Arms With Spring Cups
- Ford Racing Progressive Rate Lowering Spring Kit
-Front Lower Ball Joints
-KYB Front Struts
-KYB Rear Shocks
-KYB Rear Quad Shocks
-Eibach Anti-Roll Sway Bar Kit for Front And Rear
-Urethane Transmission Mount Red
-Prothane Urethane Transmission Crossmember Bushings
-Maximum Motorsports Caster Camber Plates
- Prothane Urethane Rear Spring Isolators
-Prothane Front Spring Isolators
-Steeda Adjustable Rear Upper Control Arms
- Steeda lower Control Arms
- Steeda Bumpsteer Kit For Power Steering Rack Gold color
-AGR Power Steering Rack
-New Power Steering Pressure Hose
Exhaust :
-BBK Chrome Long Tube Headers 1-5/8in
-MAC Off-road Pro Chamber Mid-Pipe
-Flowmasters
- a catted mid-pipe will be included in the sale
Other:
-5 lug conversion
-Cobra disk brakes all around
-1999 tremic transmission
-5.0 “brand” shifter
-1996 mustang wheels
-Saleen body kit
-5 disk changer, motorized screen, two sony explode sub woofers
-white face gauges
-aftermarket seats (drivers side is warn)
-single piece headlights
- recent oil change 02/04/14
-new tires 10/15/13
The car is 25 years old so it is not perfect. Here are some of the things you need to know.
-it still has the stock 2.73 gears in the back
-the gas door no longer pops with the button
-the rear window defroster is not working
-the seat belts are weak (I have new seat belts just not installed, will include in sale)
-passenger side door ding from shopping mall skateboarder crashing into it
-hood ding from supermarket lady in an SUV backing into it
- Front Saleen style valance needs to be replaced
- paint needs attention
- air needs to be recharged
-the long tube headers are a tight fit with the 1999 transmission. Sometimes the clutch fork rubs against the pipes
I have a folder full of recipes
Engine:
-Rebuilt 306
-custom CAM
-24lbs injectors
-new PVC valve
Suspension:
-KYB Front Struts
-KYB Rear Shocks
Exhaust :
-Flowmasters
Other:
-5 lug conversion
-Saleen body kit
-white face gauges
-new tires 10/15/13
