$9500 OBO---- Car is located in SW MO (Joplin, MO Area)
Clean and clear title in my name. No trades. Make a legit offer, low ball offers will be ignored Read the entire ad before asking questions. I'm selling so I can move onto a coyote platform car.
There is nothing wrong with the car, it does what it should and runs great for a 2v. 59xxx on body 36xxx on engine (have documentation for the pi motor swap done August 2017) Makes 409/395 on a dyno jet at 9.88lbs of boost Car ran [email protected] two weeks ago at Mokan Dragway. Has more in it for sure.
I do not need help selling and no I don't want to cash a check for a prince. Email reply or call/text fouroneseventhreenine2147six Please don't call or text after 9pm.
Engine: 2011 pi crown vic motor (I built a motor previously that did not survive the dyno time) Stock heads with arp head studs Todd Warren custom blower cams (226/230 547/550 115lsa 5 degrees advance) Trick flow adjustable crank gears--Crank has a full key way Arp crank bolt and cam bolts Upgraded valve springs PI intake Pro products plenum and throttle body (75mm) New alternator New power steering New water pump Screaming demon coil packs Taylor 9mm wires Trick flow cam covers Billet overflow tank Billet power steering reservoir Catch can with filter, pcv has been eliminated BR7 spark plugs
Exhaust: Mac Long tubes 1 5/8 Mac Off road X pipe SLP LM1 Catback
Fuel System: FRPP 80lb injectors 255 single speed pump (98 harness has been modified to support) Stock basket has been drilled to eliminate sucking the sump dry Kenne Belle Boost a pump on 3psi Hobbs switch
Procharger: P1sc head unit Sent to Procharger in December 2016 for new seals, impeller balancing. All bearings checked out as good per them (Have paperwork to support) 1000 miles or less on new seals 8 rib setup, 3.2 upper/6.78(stock) lower. 12/13lbs at 6300 rpm Green 8 rib belt and a spare green belt Thumper RR billet tensioner w/8 rib pulley 3 core intercooler Big red race valve SCT BA5000 MAF T-bolt clamps Turbo Guard filter (have the procharger inlet with a filter and another filter)
Transmission: 4r70w that's been built to hold 800 hp Full manual valve body Circle D 3500rpm convertor TCI Deep aluminum pan External Tran's cooler SFI flex plate (6 bolt) with Arp bolts FRPP Speedcal (in glove box to protect from heat)
Suspension: UPR Tubular K with stock control arms Koni adjustable Struts and shocks Steeda Springs Caster camber plates (unsure of brand) 3 bolt Rear strut tower support Steeda rear lower control arms with drop brackets Weld in Sub frames w/seat brackets (not full length) Bump steer kit Poly sway bar bushings with upgraded end links
Rear End: LRS 28 spline hardened axles 3.73 gears Drake cover with girdle support Moser main studs New wheel bearings and seals FRPP Aluminum drive shaft
Interior/Gauges: Auto meter Boost and Trans temp gauges Innovate wide band Triple a-pillar gauge pod Raptor Shift light White face gauges Billet pistol grip shifter handle Carbon fiber frpp shifter boot Clean tan interior Aftermarket remote start and alarm Kenwood Radio with from what I can tell kicker rear deck and possibly door speakers, non Mach 460 car Billet AC knobs and headlight knob Mach 1 pedal covers All locks/windows/mirrors work as they should
Brakes Drilled and slotted front/rear rotors Good pads NON Abs car
Wheels/Tires: 98 real Cobra wheels 245/45/17 summitomo front 275/40/17 Nitto drag radials rear Great tread on both 1 inch rear wheel spacers And 17/15 SVE dark stainless drag setup. Mickey T front runners (26x6) Mickey T ET Street R 26x10.50 rears These have 5 passes and 50 street miles on them at most
Extras: Tim Donothan tubular front bumper (better intercooler clearance) Boss rear spoiler Boss Side scoops SCT 3 tuner--Bob Monks tuned (STL Mustangs) Lakewood drive shaft loop New heater core just installed AC was recharged (after heater core install) and is working perfectly Tinted windows (rear was just redone) Remote keyless and remote start on aftermarket alarm works as it should 2 keys both with key fobs Pats has been disabled in the tune New battery Working fog lights w/fog light mod Clear aftermarket headlights MMD hood struts
Make an offer, I do not have to sell as the car is paid for and can sit for the right buyer. I'm wanting to get into a 13/14 coyote car but no i don't want any partial trades of them with me giving cash at this point. I have a very specific car/options I'll be after. Less
