2 questions for stangnet gurus!
  • Thread starter Thread starter D347643
  • Start date Start date Dec 11, 2005
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Dec 11, 2005
  • Dec 11, 2005
1. By advancing a cam (I advanced my stage 1) does it affect idle quality?
2. I am hearing an intermittant hiss from my return fuel line. I traced the hiss up to the regulator and I am pretty positive it is coming from inside the line itself. I have an aftermarket adjustable regulator I bought from 5.0 resto. I figure the noise is from the regulator releasing pressure to keep it at the 37psi i set it at. Shouldnt the pressure release be a constant release and not intermittant?
thanks
Drew
RMODEL65
313
brunswick ga
Dec 11, 2005
  • Dec 11, 2005
timing
advancing will smooth the idle slightly and also make the car run cooler just make sure it isnt detonating
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Dec 11, 2005
  • Dec 11, 2005
thanks, anyone else?
Drew
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Dec 12, 2005
  • Dec 12, 2005
anybody?
HISSIN50
34
129
Dec 12, 2005
  • Dec 12, 2005
Rmodel, are you talking about advaning the cam or advancing ignition timing?
HISSIN50
34
129
Dec 12, 2005
  • Dec 12, 2005
Drew, what happens if you remove and cap the vac line on the FPR (so it is not connected to the FPR)?
I have not listened for any noises like that, so I am not sure. The FPR should constantly bypass fuel, and like at idle, it should be fairly consistant in this means.
No great ideas from me though. Good luck.
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Dec 12, 2005
  • Dec 12, 2005
yeah i think it should be a constant steady release also, not intermittant. I checked the vac line going to the fpr and there is no gas in it so its not leaking. Ill try and cap it off and see what happens. It's crazy, the hiss is pretty loud.....you can hear it if you are changing the fp for example or even setting the timing. thanks hissin!
anyone else on the cam timing or hiss from return line?
thanks
Drew
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Dec 12, 2005
  • Dec 12, 2005
i mainly want to know about the fpr and it the release should be steady or not? and that hissing noise im hearing.
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Dec 12, 2005
  • Dec 12, 2005
anyone else?
bcd
274
arab al
Dec 12, 2005
#10
  • Dec 12, 2005
  • #10
The TFS stage 1 cam comes with a 4* advance ground into it
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Dec 12, 2005
#11
  • Dec 12, 2005
  • #11
i think most of their cams do, thats why the trick flow cams pull pretty decent up top. I advanced it 2 more degrees to get even more topend...suggested by thumper.
thanks
Drew
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Dec 12, 2005
#12
  • Dec 12, 2005
  • #12
ok update, called kirban and they said that if the reg was bad then there would either be no pressure or very low pressure if the diaphragm had even a pinhole leak in it. come on guys, any idea? I thought maybe the line between the rails and under the car may be plugged but its perfectly fine. I havent checked the fuel rail though. any idea what could cause a hissing noise from the return line? what if it was partially clogged? maybe someone else could listen on their stang and see if they hear the same noise...maybe its normal but i doubt it.
thanks
Drew
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Dec 12, 2005
#13
  • Dec 12, 2005
  • #13
anyone"?
HISSIN50
34
129
Dec 12, 2005
#14
  • Dec 12, 2005
  • #14
If the return line was clogged, the pressure reading would be higher in low demand situations (i.e. idleing).
Otherwise I would start spraying some oil or other non-flammable liquid around that area and see if it shuts up the noise.
I dont have any ideas but figured a bump might help.
Good luck.
  • dan50
  • Jul 18, 2026
dan50
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
