  • SN95 4.6L Mustang Tech
2000 gt problems...
  • Thread starter Thread starter saleen_lover21
  • Start date Start date Aug 8, 2005
saleen_lover21
  • Aug 8, 2005
What's up guys...I'm getting a code for random misfire, will simply replacing the plugs and plug wires solve this problem? the car is fine on low rpm, but when I try to go full throttle it falls on its face...
trinity_gt
3,125
81
99
Canada
Aug 8, 2005
  • Aug 8, 2005
Your car will have COP (coil on plug) and doesn't have plug wires, per se. Depending on the miles, the plugs may indeed be shot. Make sure you carefully follow the torque specs if you replace the plugs.
This random misfire...any mods done to the car lately? Like...underdrive pulleys?
T
TripleBlk
312
Cape Canaveral FL
Aug 8, 2005
  • Aug 8, 2005
you have plug wires ? Have you changed the filters recently (air and fuel ) ?
J
justin01gt
76
upstate ny
Aug 8, 2005
  • Aug 8, 2005
how many miles, when has your fuel filter/air filter/plugs been changed
With a 2000 if your under a 100k and u dont have to many mods and such i doubt its ur plugs
saleen_lover21
  • Aug 8, 2005
sorry...i don't know much about the new 4.6s...I used to have a 93 5.0 which was very easy to work on...but, my car has 100,000 miles exactly...and I've changed the fuel filter and I have a K&N air...so, i'm lost...
M
matts90gt
46
  • Aug 8, 2005
Does the car feel like it's loading up at WOT but nothing happens or the car doesn't get up and go like it use to? What is it like at idle? If it is rough at idle, it sounds like one of your coil packs isn't allowing for any fire. If this is the case, while the car is at idle, on the coil pack, there is a electrical adaptor, unplug and plug these one at a time. if the car idles rougher, then that particular ciol pack is fine. Find the coil pack that doesn't make the idle rougher. That will be the one that is miss firing. This is a 3 minute job and it might save you some time. Process of elimination.
saleen_lover21
  • Aug 8, 2005
it seems fine at low rpm, but i can't rev the car over about 4,000 rpm without it stumbling...it's also burning gas richly...
Superhereaux
chicks make me feel inadequate
538
South Texas
Aug 8, 2005
  • Aug 8, 2005
just pull the plugs and look at them, no big deal
if they look fine then you can stop worrying about them and start looking elsewhere
  • Gulftown980x
  • Jul 29, 2026
squeak93
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
1970 Mach 1 voltage regulator
  • 70ivygreen
  • Oct 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 27, 2026
Mcmahst
