  • SN95 V6 Mustang Tech
2000 Mustang Dash Lighting
  • Thread starter Thread starter CStaresinic
  • Start date Start date Feb 21, 2010
C
CStaresinic
Las Vegas
Feb 21, 2010
  • Feb 21, 2010
All of the dash lights (check engine, o/d, low fuel, etc.) are out on my 2000 mustang except for the seatbelt and batter lights. I replaced the check engine lightbulb after discovering it was blown, only to have it stop working about 2 days after i replaced. I am wondering if this is a fuse problem and, if so, which fuse needs replacing.
Thanks
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Feb 21, 2010
  • Feb 21, 2010
Check the center console grounds and fuses
Check fuse F2.21(5a), F2.34(20a), F2.5(15a), and F2.37(5a) in the Central Junction Box (CJB). However, not a bad idea to check all of the fuses.
Have you done any recent audio work? Do you have a big sound system?
The cluster shares the grounds with the radio and other devices around the center console. Check the grounds to see if loose, disconnected, over loaded, burnt, or anything effecting the quality of the connection.
C
CStaresinic
Las Vegas
Feb 23, 2010
  • Feb 23, 2010
Nope just the stock ford stereo system.
So replacing the fuses you mentioned and the bulbs in the dash should fix the problem?
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Feb 23, 2010
  • Feb 23, 2010
Fuses usually blow for a reason. However, isn't the first order to find out IF the fuse is BLOWN. Next find out WHY it blew?
Since you stated that you did work on the cluster, is it possible the two are related? Did you remove the battery negative when you did the work? If not, you could have created a temporary short and blew it then.
Also possible that something was damaged during the repair.
Someone out in Internet land can't possible tell you if replacing a fuse will fix your problem without knowing why the fuse blew in the first place. It's time to drag out the tools and start trouble shooting.
Feel good saying for the day:
There is no elevator to success. You have to take the steps.
slowfashow
61
29Palms california
Feb 26, 2010
  • Feb 26, 2010
I had all my dash lights and AC lights go out once, all I did was check the fuses one by one and I found a blown fuse. I replaced it and I was happy again.
M
myred65
  • Oct 4, 2011
If the fuses are all good, then check the resistor in the headlight switch. This was my issue when I had no dash lights.
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
