302 to 5.0
  • Thread starter Thread starter oneturboneeded
  • Start date Start date Aug 26, 2008
O
oneturboneeded
28
  • Aug 26, 2008
im swapin in a new 5.0 are the engine mounts and all the same? on the out side i know it is a 50 ounce imbalance vers a 28ounce. thanks
BornInAFord
199
Bend, OR 97701
Aug 28, 2008
  • Aug 28, 2008
Yep, the same mounting points. I'm sure you know this already, but don't forget to plug the dipstick hole in the lower left of the block if you are going to use an earlier style timing cover dipstick location. If you do use the early style mechanical fuel pump (also with the vintage timing cover), you will need to add a vintage style fuel pump eccentric to the timing chain end of your camshaft and get a proper depth timing chain sprocket set. There are other changes you'll need, I'm sure someone will chime in. But, the mounting points are the same...
O
oneturboneeded
28
  • Aug 29, 2008
sweet thanks solves lots of questions quick.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
