Expired 306 Short Block A4 Block/carrillo Rods/je Pistons/accufab 75mm Tb/edelbrock Intake Fuel Inj/pushrods
50racer
10
South Florida
I am parting out my project and have the following engine related for sale:
A4 long rod 306 short block, Carrillo 5.3 rods, JE Pistons 8.5:1, ATI Damper neutral balance, roller master timing chain, Canton 8 qt pan, Meziere Water Pump, Comp Cams Intake/Exhaust lift .622 Duration @.050 int 236/exh 244 Lobe Sep 114. Don't feel like pulling off the water pump and timing chain to pull out cam so I am selling it with it. The water pump is brand new. The motor has 6 passes on it since built (9.40 @145 avg single t76 turbo) - $5000 obo
Prime One push rods 6.600 .080 wall (set of 16) - $50 shipped
Prime One push rods 6.300 .065 wall (set of 16) - $50 shipped
75mm Accufab Throttle Body and EGR delete plate - $180 shipped
90mm throttle body elbow to carb intake - $150 shipped
Edelbrock victor jr convert for fuel injection, 160lb injectors, fuel rails, ARP bolts, polished thermostat housing - $750 shipped
Rare SAAC valve covers - $300 shipped
The turbo kit is also for sale and will be listed under the power adders section.
Email or text 954-465-7146. Please specify what you are inquiring about. Thank you for taking the time to look. Parts are in Coral Springs, FL
