347 make more hp than a 351?
  • Thread starter Thread starter Chietala
  • Start date Start date Feb 5, 2007
Chietala
111
Sacramento
Feb 5, 2007
  • Feb 5, 2007
Does anyone know why the 347 would make more power than a 351?
Same h/c/i.
Aliate X
602
Rockland NY
Feb 5, 2007
  • Feb 5, 2007
More RPMs with the 347. Less rpms with the 351 = more torque.
Modular2v
3,222
23
99
oklahoma
Feb 5, 2007
  • Feb 5, 2007
the physics of the 347 make it more powerful....example: larger bore
Chietala
111
Sacramento
Feb 5, 2007
  • Feb 5, 2007
Chietala
111
Sacramento
Feb 5, 2007
  • Feb 5, 2007
Are you saying the 351 makes more torque?
I don't think the .040 bore increase makes much of a difference.
I was thinking more along the lines of the rod to stroke ratio???
Anyone else have some input??
Aliate X
602
Rockland NY
Feb 6, 2007
  • Feb 6, 2007
More rpms = more HP and less torque, thats why F1 cars make like 800hp on a 3.0L v8 which also makes about 200tq, they rev to 24,000 rpms. A 351 will rev about 6k or so assuming you have the stock bottom end.
86nu
94
Birmingham, Al
Feb 6, 2007
  • Feb 6, 2007
MY 351 See's 7k all day long on the track, stock crank, rods, forged pistons, clevite bearings balanced to .5 grams, and it has yet to have a problem in the last 3 years.
the car leaves at 3k at the track and run s 6.4x's all day long on the laughing gas
302RollinHard
Columbus, OH
Feb 6, 2007
  • Feb 6, 2007
You will more power with a 347 than with a 351 with the same HCI. But you will have more bottom end torque at a lower rpm with a 351 than a 347 (just my opinion). It is all about the bottom end at that point (compression ratio, bearing clearances, etc) with the same HCI. 351 has more rotational mass and larger bearings (read: more bearing surface means more frictional losses but stronger overall), which will affect power ratings. A 351 does have a more favorable rod to stroke ratio, a little stronger block, and the ability to stroke it out to 408 c.i. It is hard to compare the two because you wouldn't put the same cam or probably even heads on a 347 and a 351. It is all in the complete setup. That is only my 2 cents, though.
Modular2v
3,222
23
99
oklahoma
Feb 6, 2007
  • Feb 6, 2007
i was giving the .030 bore increase as one example.....the stroke to rod ratio greatly increases torque!
STANGateURlilSS
716
USA & SANDBOX
Feb 6, 2007
#10
  • Feb 6, 2007
  • #10
.030" doesn't make that much difference.. what makes the difference is the rod ratio, piston height..
Modular2v
3,222
23
99
oklahoma
Feb 6, 2007
#11
  • Feb 6, 2007
  • #11
wow....thank you ! You are only the 2nd person to point out something i already knew!!!!! i was just giving ONE example....there are several reasons!
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
1965 mustang 351 850 hp+ primary tubes 1 7/8 or larger and a 3 inch or larger collectors?
  • 427nostang
  • Jun 4, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 7, 2026
DadLife0724
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
W
top loader transmissions
  • WilliamJCC.
  • Jun 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 6, 2026
70mstang
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
