347 not turning....help fast
  • Thread starter Thread starter Mizark347
  • Start date Start date May 18, 2004
  • 3
First Prev 2 of 3 Next Last
Mavrick
2,264
Collingwood, ON
May 18, 2004
#21
  • May 18, 2004
  • #21
Is it cranking at all?
TT91
1,536
Paramus, NJ
May 18, 2004
#22
  • May 18, 2004
  • #22
keep charging it..
M
Mizark347
145
Detroit
May 18, 2004
#23
  • May 18, 2004
  • #23
its cranking very little...gets denied and then stops...its charging
Mavrick
2,264
Collingwood, ON
May 18, 2004
#24
  • May 18, 2004
  • #24
Try swapping battery's from your truck, see if the stang will crank with your truck's good battery
TT91
1,536
Paramus, NJ
May 18, 2004
#25
  • May 18, 2004
  • #25
it should crank with your trucks good battery. If it doesnt..hmmmmm...brainstorming....
M
Mizark347
145
Detroit
May 18, 2004
#26
  • May 18, 2004
  • #26
swapping battery is the same jumping isnt it?
Mavrick
2,264
Collingwood, ON
May 18, 2004
#27
  • May 18, 2004
  • #27
Jumping it = using booster cables to connect the battery from your running truck to the battery of your stang, and starting the stang while its hooked up. This way, your truck is giving the stang power.
M
Mizark347
145
Detroit
May 18, 2004
#28
  • May 18, 2004
  • #28
truck battery is the little side terminal only anyway. so your saying if i go get a new optima battery to replace the old motorcraft i bought it with....its should do the trick?
TT91
1,536
Paramus, NJ
May 18, 2004
#29
  • May 18, 2004
  • #29
It should do the trick. I would try a new battery, and it if doesnt work, return it.
Mavrick
2,264
Collingwood, ON
May 18, 2004
#30
  • May 18, 2004
  • #30
Yep!
M
Mizark347
145
Detroit
May 18, 2004
#31
  • May 18, 2004
  • #31
The crank is alot harder to turn than my old 302 though. thats why im thinkin the starter doesnt have enough torque. I have a ton of voltage, i can any aplliance to its fullest.
TT91
1,536
Paramus, NJ
May 18, 2004
#32
  • May 18, 2004
  • #32
WHAT???!!??
It may be the starter after all, but im using the same worn out starter as my old 302 on my new 331 with no problems at all. I guess the starter is your next thing in line to troubleshoot.
Mavrick
2,264
Collingwood, ON
May 18, 2004
#33
  • May 18, 2004
  • #33
Are you measuring the voltage with a voltmeter, or going off your stock gauge?
I'd still try a new battery, if that doesnt work, you can return the new battery!
M
Mizark347
145
Detroit
May 18, 2004
#34
  • May 18, 2004
  • #34
i think im gonna try a high torque starter....keep ya posted....thanks for everything.
TT91
1,536
Paramus, NJ
May 18, 2004
#35
  • May 18, 2004
  • #35
good luck brother!
W
wisconsinboy
78
eau claire wisconsin
May 18, 2004
#36
  • May 18, 2004
  • #36
hey check your grounds too that was my problem. put a new ground from the block back to the battary and it took a bit to get it goin cause of the compression but it fired up.
M
Mizark347
145
Detroit
May 18, 2004
#37
  • May 18, 2004
  • #37
Brand new optima red top still nothin...the ground wire is brand new.....should i find a new spot to ground it?
Mavrick
2,264
Collingwood, ON
May 18, 2004
#38
  • May 18, 2004
  • #38
Try cleaning the grounds really well with sandpaper, make sure they are nice and clean, that way you know the grounds are no longer a problem.
Also check the ground that goes from the REAR of your motor and bolts to the firewall, i've heard it's important to have grounded.
M
Mizark347
145
Detroit
May 18, 2004
#39
  • May 18, 2004
  • #39
would it still try to start with a bad ground? because the starter tries, just cant spin the motor fast enough.
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
May 18, 2004
#40
  • May 18, 2004
  • #40
I've gotta get on this.
Your stock starter shoudn't have any problem's turning over that 347. Hell I run a factory starter on my big 10.8:1 408 Stroker, and it does alright. Something dosn't seem right here. Usually if a starter is shot it's shot. They usually don't power out or anything like your's, they usually just die or won't turn over at all. It's just not getting enough power to crank that motor over is what I think. Try the solenoid for the hell of it. Either that or you messed up on the clearences (Bearing's, Rings etc.) and the clearences are so tight that the starter dosn't have enough power to turn over such a tight engine. How hard was the motor to turn over by hand? Was it really hard? Did you have to you a snipe?
  • 3
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
