  • 1994 - 1995 Specific Tech
351 headers
  • Thread starter Thread starter ARVtheHPjunki
  • Start date Start date Oct 28, 2004
A
ARVtheHPjunki
36
  • Oct 28, 2004
who out there knows of a manufacturer that makes 351 swap headers for our years(94-95). I would prefer long tubes, but want to find all options.
1slow95
1,797
ohio
Oct 28, 2004
  • Oct 28, 2004
www.kookscustomheaders.com
I think BBK, MAC, and Hooker also work if you use a fox-body transmission and bellhousing. 5-speed only, that is.
Y
yellow1995Cobra
2,959
Massachusetts
Oct 28, 2004
  • Oct 28, 2004
Kooks is the only way to go. They are the most $$$, but the best quality and fit, plus they come is various primary sizes.
zenboy99
2,212
Madison, WI
Oct 28, 2004
  • Oct 28, 2004
Hooker supposedly makes Long Tubes for 94-95's with 351's. They adveritise them, but I've never seen them.
SuperDust22
The Power of Pixie Dust?!
Oct 19, 2003
1,821
Gilbert,AZ
Oct 28, 2004
  • Oct 28, 2004
will the smae header fit a 351 and a 302 heads. I have 351 heads out of a 70' car if I bought some new AFR heads would the headers still fit?
Dustin
A
ARVtheHPjunki
36
  • Oct 28, 2004
Dustin
they will fit. the afr heads are actually 351 heads.(1/2" head bolts) the bolt patterns are identical. real 302 heads only have 7/16 head bolts.
Who has seen the hooker headers advertised and where.(351 swap headers for 95). Cause I have not been able to find them on the net yet.
M
mackey
1,284
Beverly, Massachusetts
Oct 28, 2004
  • Oct 28, 2004
Dustin
Yes the heads for 351/302s are the same.
Y
yellow1995Cobra
2,959
Massachusetts
Oct 28, 2004
  • Oct 28, 2004
Dustin
Depends, if you get a afr225 head, your gonna need the kooks headers. For one, they are raised ports, second, the exhaust ports are so huge they need a 1-7/8 primary to cover them, and the bolt pattern(for header) is different.
A
ARVtheHPjunki
36
  • Oct 28, 2004
I have been on both kooks and hooker websites and neither one shows any long tube 351's. Only 302. Hooker does show a short tube 1 5/8", but I'm putting together a 427ci motor and need at least 1 3/4x30. Do I have to call kooks for a custom application?
Y
yellow1995Cobra
2,959
Massachusetts
Oct 28, 2004
#10
  • Oct 28, 2004
  • #10
I never really checked out kooks website, i called them directly. They do have longtubes of course! Tell them the heads your using, engine, etc etc and they will give you a part # for the headers. Then you will need to call one of their distributers, i went through bennet racing and everything went smoothly. Bennet racing said 3 week wait, had them in 2 weeks they were 630 uncoated.
SlowGT
826
Columbia Co, PA
Oct 29, 2004
#11
  • Oct 29, 2004
  • #11
I'm thinking 1-3/4 will be a little small for that many inches. Call Kooks and ask. I'm betting they tell you 1-7/8-->2" step headers. Guess it'll depend on your heads and RPM. They sent me 1-7/8 for my N/A 408 @ 7200rpm with AFR 225's.
The difference between the Fox & SN95 headers are due to the difference in the steering setup.
SuperDust22
Oct 19, 2003
1,821
Gilbert,AZ
Oct 29, 2004
#12
  • Oct 29, 2004
  • #12
Here is my problem after I finish the bottom end I want to get the motor in the car. I was going to leave the stock 351 heads on there. Ported of course. Maybe new springs etc. I heard they can be a very good head. I will buy heads later but that's what I am doing to start. The main question is if I buy a set of long tubes headers for the 351 will they fit a set of Edelbrock Vic Jr later. I don't want to buy headers twice.
Dustin
A
ARVtheHPjunki
36
#13
  • Oct 29, 2004
  • #13
edelbrock victor jr. heads have the exhaust port raised .130". so the fit would be slightly questionable. If you purchase heads that have the intake and exhaust port locations in the factory positions(such as afr 185's) they will fit exactly the same as your stock 351 heads.
D
dirtyo2000
31
#14
  • Nov 1, 2004
  • #14
Well i have a 396 set up with afr 205's i called cooks and the headers they sold me ran me 540 and all i had to do was tap the number 8 tube to clear the steering linkage no bid deal. the primaries are 1 7/8 fit was great just have to put them in in the right sequence, and did it with all the accessories on the motor and fully bolted down no jacking or breaking the motor loose. the stainless steel was 620 i think. i brought the steel, fit them in bent the 8 tube and had the coated by jethot. worked out well but what killed me was the egr tube still trying to get that sorted out because im keeping all the fuel infection on the car
I
I3oostedCubes
#15
  • Nov 1, 2004
  • #15
I have a 351, 185 AFR's in a SN95. I don't want Kooks custom headers or long tubes. I don't care what headers are made, I jsut need somethign basic to bolt on and cheap. I'am going turbo so I don't need $500+ headers.
Who sells what I'am looking for?
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
W
top loader transmissions
  • WilliamJCC.
  • Jun 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 6, 2026
70mstang
G
S550 Headers
  • gray owl
  • Feb 1, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Feb 1, 2026
gray owl
G
T
New Guy from Southeast Missouri
  • tcooke11
  • Jan 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 17, 2026
TomcatPC
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
