  • SN95 4.6L Mustang Tech
4.6 Head questions
  • Thread starter Thread starter ThunderLips
  • Start date Start date Apr 21, 2004
T
ThunderLips
  • Apr 21, 2004
I've read that my 1996 heads can out flow the 1999+ PI heads with new Camshafts.....What all would i need to do to change the camshafts and what would be a good Choice....Thanks This is the Flow Chart
4.6 Cylinder Head Flow Data
(Courtesy of Livernois Motorsports)
Lift
in Inches
------------Stock--------------Ported
----------'96------'01----------'96------'01
.100-----46-------54-----------61-------60
.150-----66.6-----78-----------89-------86
.200-----84.5-----98-----------111.5----116
.250-----103.5----119----------131.3----141
.300-----121.3----135---------46--------160
.350-----134.7----145---------159.6-----169
.400-----147------156---------173.3-----176
.450-----159.4----161---------185-------182
.500-----170------166---------188-------185
.550-----176------168---------192.5-----186
Part Identification 1996-01**
Would these numbers Change if i shaved the heads?
Solid Snake
Banned
Nov 26, 2002
940
GA
Apr 21, 2004
  • Apr 21, 2004
Ummm, thats a negative. The actual 99+ HEADS (not the valves, cams, etc.) flow much better than the 96-98 heads.
D
DJT03GT
187
New Jersey
Apr 21, 2004
  • Apr 21, 2004
New Camshafts will help you, but that wont change the sizes of the intake and exhaust ports. Maybe if you have your heads ported and polished you would out flow newer heads. But in my opionion if you were to do all that, might as well have P&P ported and polished and thrown on there. Then with some cams, would make some good power.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Apr 21, 2004
  • Apr 21, 2004
just get some used PI heads.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 21, 2004
  • Apr 21, 2004
there was an article in 5.0 magazine about this. if you go and remove the emissions blocker next to the intake valve, port the chambers, and put PI intake valves in along with the PI cams then yes you could theoretically outflow PI heads. however ported PI heads will easily outflow NPI heads. the reason that they did so much work with the NPI heads is incase you dont want the CI increase when you do the PI headswap.
T
ThunderLips
  • Apr 21, 2004
Right there is the Flow chart saying that a port an polished NPI head with .550 lift out flows the PI heads ported and polished. What I wanna know is what all is need to changed the Cams.....Anyone got a used set up PI heads to sale? thanks
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 21, 2004
  • Apr 21, 2004
to change the cams if i remember right you need cam cover gaskets, new cam bolts, new timing chains(not required but a good idea), front cover gasket, RTV. thats all i can think of off the top of my head. also a good dyno tune after would be a good idea.
Another Head Flow Chart
  • dcurtis
  • Sep 6, 2007
4K
Fox 5.0 Mustang Tech Sep 7, 2007
86bluecobra
PI Headswap Write-Up
  • 5spd GT
  • Aug 26, 2007
67K
SN95 4.6L Mustang Tech May 4, 2020
Thomas Camp
T
cool read, fastest 2v/4v cars around
  • Winters98GT
  • Nov 7, 2007
6K
1996 - 2004 SN95 Mustang -General/Talk- Oct 30, 2009
96gts4.6L
9
2001 Modular 4.6 Head Flow Data
  • [Twitch]
  • Apr 13, 2005
2K
SN95 4.6L Mustang Tech Apr 13, 2005
hotmustang331
stangnet's 1/8 and 1/4 mile times
  • Winters98GT
  • Nov 8, 2007
  • 2 3
9K
1996 - 2004 SN95 Mustang -General/Talk- Dec 22, 2007
Winters98GT
