454s on a 66
  • Thread starter Thread starter Capt Dan
  • Start date Start date Mar 8, 2009
Capt Dan
237
College Station, Texas
Mar 8, 2009
  • Mar 8, 2009
Mustangs Unlimited says they fit.
Dodgestang doesn't have a lot of info on his site for that size. 17 x 8 w/ 4.25 bs
Anyone done it? pics?
latamud
791
Tampa, FL
Mar 8, 2009
  • Mar 8, 2009
Better to go with a 4.75 or 4.5 bs.
Capt Dan
237
Mar 9, 2009
  • Mar 9, 2009
I realize that, but the 454s are not offered with that bs as far as I know.
latamud
791
Tampa, FL
Mar 9, 2009
  • Mar 9, 2009
Capt,
a 4.25 bs 8" wheel will bolt on. You should run a narrower tire, and possibly need to roll the fender lips. It will look similar to taking a 4.75 wheel and using a 1/2" spacer widening your track width except it will have a deeper dish. Given all that, if you can find a tire that is 1" narrower than a 245/40-17 or 245/45-17, you could fit a 17x8 with 4.25 bs on a 66.
A 205/50-17 or narrower tire will tuck under a tight rolled fender lip. You might be able to fit wider if the fender lips are above the tire tread.
dodgestang
1,360
Cecil County, MD
Mar 9, 2009
  • Mar 9, 2009
Other than the whole stretching a tire onto a larger than recommended rim width range and all the curb rash that will give you from the lack of a sidewall and all the pot hole dings in the edges of the rim for the same reason...sure it bolts right on with that size .
latamud
791
Tampa, FL
Mar 9, 2009
  • Mar 9, 2009
Nick, I run a 205/40-17 on a 17x8 with 4.75bs on my daily driver 63 wagon without any curb rash. A 205/50-17 tire has 7.8+/- tread width depending on what brand.
I suppose on a 66 with the 4.25 454s with the front control arms brought all the way inward and a vario-centric camber kit bringing the lower control arms inward, this could help if you want a wider tire and tucked.
Or, try an alternative wheel. These guys will custom your wheel bs from 3.75-5.25 on a 17x8.
Team III Wheels [AC III Wheels]
dodgestang
1,360
Cecil County, MD
Mar 9, 2009
  • Mar 9, 2009
Yeah but there's no potholes in Ohio and you don't parallel park it
You're still shrinking the sidewall and installing the tire on a rim not recommended by the manufacture. I'm sure it is done all the time without issue but you do increase exposure to damage to the rim. Did you buy the tires and then take the tire and the rim to shop to mount them?
SNAKEPILOT
112
  • Mar 9, 2009
There are a lot of wheels that look very similar to the 454s. Get wheels that have the right BS and width for your application.
The section width on a 205/40/17 tire is wider than the tread width, about 8.3" but a 17x8 wheel is 9" wide. That's about 3/8" of exposed metal that will quickly develop rash. Looks ricey in my opinion too.
M
Looking for a passenger side AC Compressor mount
  • mustangTodd
  • Feb 10, 2026
Classic Mustang Specific Tech Aug 22, 2026
s_mi11er
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
K
351w engine swap
  • Killer351w
  • Jan 21, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jan 21, 2026
Killer351w
K
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 19, 2026
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
