5 Speed Tight
  • Thread starter Thread starter Marshall
  • Start date Start date May 24, 2005
Marshall
225
Qld Australia
May 24, 2005
  • May 24, 2005
I have just started driving with a T50D 5spd mannual, cable clutch. The gears change fine except when I'm stationary and try to put it in first. It just dosent want to slide in and I have to wriggle and push harder than I beleive it should need.
Changed to Redline oil with marginal effect, maybe it's a tiny bit better.
Is this a common problem with these boxes? Is there a fix?
Really appreciate any advice.
Tks Marshall
Stang8URMPRT
1,100
Daytona Beach, FL
May 24, 2005
  • May 24, 2005
Yep.... it's very common. What you need to do if it doesn't want ot go into gear is put it back in neutral... let off the clutch, then press it again... it should go in fine then. Last thing you want to do is PUSH on the shifter to get it into gear. Only thing you will accomplish is bending or breaking the brittle cast aluminum shift fork. Hope this helps.
Nick
HISSIN50
34
129
May 24, 2005
  • May 24, 2005
Marshall, are you running D4? Thicker oil could cause an issue (it seems to me that you Aussies are a bit fond of the thick stuff - e.g. I used to think 20W-50 motor oil was thick till I saw what you guys have available. ).
Anyhow, good luck with it and bump for ya.
Marshall
225
Qld Australia
May 26, 2005
  • May 26, 2005
Yeah - Major oil companies sell 80W - 90 for gearbox oil here, its a bit like mayple syrup!
I put Redline trans fluid in (nearly $100 for 3 litres) boy, I'm keeping the US economy going all by myself.
Redline Seems to have fixed the problem but only after about 50 miles driving, dont know why that is so. I'm told that these boxes are tight to go in first even when new so I'll just have to get used to it.
MarshallView attachment 513537
HISSIN50
34
129
May 26, 2005
  • May 26, 2005
Man, those prices are outrageous (the exchange rate was not that bad when I was in Sydney, many, many years ago. ).
I thought you guys had motor oil with weights like 30W-80 or something similar to that (I see Aussies post numbers like that on the oil forums).
Good lookin motor/trans.
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Electrical Aod-t5, Speed Density To Mass Air, 02 Harness Differences, Etc
  • Mustang5L5
  • Aug 23, 2016
3K
Fox 5.0 Mustang Tech Aug 24, 2016
larrym1961
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
Taurus Fan And Fal 33054 Install On A Fox
  • No.11
  • Oct 4, 2016
5K
Fox 5.0 Mustang Tech Oct 11, 2016
MFE92
DISCOURAGED! Should I replace, keep or give her up???
  • killer medic
  • Feb 3, 2013
5K
1965 - 1973 Classic Mustangs -General/Talk- Mar 23, 2018
Edbert
