5-wire door lock actuators
  • Thread starter Thread starter csxfbird
  • Start date Start date Jul 14, 2004
csxfbird
26
  • Jul 14, 2004
Well I ordered a power door lock actuator setup from NPD. It's a centralized, 5 wire design, and incorporates two relays (prewired). I spent all day trying to figure out how to wire it into my Vipe 350 HV alarm...the only thing that was provided with the kit (in terms of wiring) is the color of the wires, and how they connect to the relay....they don't tell me what each wire is in term s of 12v or ground...is anyone here good with 5 wire setups?
The wires I need to use off the viper alarm are Green, which is a + unlocking, - locking output, and blue, a + locking, - unlocking output. Thanks.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Jul 14, 2004
  • Jul 14, 2004
do you have 4 or 5 wires on each relay
65 fastback
1,347
Northern VA
Jul 14, 2004
  • Jul 14, 2004
csxfbird - Sorry, I did not get to your PM yet.
Yes, this is the same kit that I have.
First, I installed my locks and wired them to a switch in the console. I tied into my horn circuit for constant (not ignition switched) 12V power. Once I had them installed and adjusted, I tied them into my Viper Alarm.
I did not use the releays that came with the lock kit, the Alarm is already on a relay. I just connected the brown and purple wires (on the door lock harness) to the blue and green leads (on the Alarm Relay). I don't remember if I went purple to blue or green - just do a quick test to see if you are locking or unlocking.
Shoot me another PM or just post here if you need more help. My remote now alarms and locks the car, then deactivates the alarm and unlocks the car.
Good luck,
Tim
65straightsick
411
Montgomery, AL
Jul 14, 2004
  • Jul 14, 2004
While were on the subject, I would like to install power door locks with the central locking system. I would like to have remote trunk release but no alarm. Is there a cheap kit that matches this description?
65 fastback
1,347
Northern VA
Jul 15, 2004
  • Jul 15, 2004
65straightsick -
Sure there's a kit that uses power locks without an alarm.
Check - http://www.a1electric.com/catalog.htm
Tim
65 fastback
1,347
Northern VA
Jul 15, 2004
  • Jul 15, 2004
csxfbird -
Here's a link to the door lock actuator installation thread. I used gp001's method over the instructions that came with the kit.
http://forums.stangnet.com/showthread.php?t=464237
Tim
csxfbird
26
  • Jul 15, 2004
Thanks a lot Tim. The locks are working with the alarm just fine now. Much easier than I thought it would be. I had this whole diagram setup that involved 2 additional relays to try and get the locks working, lol.
I do have a couple more questions regarding the install, though. I noticed that gp001 used a straight piece of threaded rod. Is there a place I can buy some, or would I have to thread the rod myself? My tools are kinda limited, since this is my dad's apartment; all my tools are back home in Arizona.
Also, how did you run the wiring from the inside of the door to under the dash?
65straightsick
411
Montgomery, AL
Jul 15, 2004
  • Jul 15, 2004
Congradulations, but i can't help with the rods. I do know that most people cut a small hole on the inside of the door and run the wires behind the kickpanel and up under the dash. At least, that is how I will do mine. Don't forget to make some sort of grommet to go around the cut hole to keep from puncturing the wires.
Good luck
G
gp001
4,401
So. Cal.
Jul 15, 2004
  • Jul 15, 2004
You can buy threaded rod at any hardware store (I got mine at Home Depot). If you don't have a die set to clean the threads after cutting the rod you can just put the nuts and hardware on first an then cut the rod using bolt cutters/hack saw/ dremel/ etc.
65straightsick
411
Montgomery, AL
Jul 15, 2004
#10
  • Jul 15, 2004
  • #10
I was looking at the power window kit from a1electric. When you order those with the $34 switch kit, does that include the wiring to the ignition or does that have to be ordered seperately? In other words, does that include everything to make the locks work or is another wiring system needed?
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
C
Help with 2007 convertible / power door lock problems
  • cwood2314
  • May 12, 2023
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 12, 2023
cwood2314
C
I
Electrical Door lock security issues
  • Icouldntthinkofaname
  • Apr 21, 2022
Fox 5.0 Mustang Tech Apr 30, 2022
I
D
Electrical No power at either power lock actuator. 93 GT
  • dbix11
  • Aug 17, 2021
4K
Fox 5.0 Mustang Tech Sep 26, 2021
manicmechanic007
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
