  • 2005 - 2014 Specific V6 Tech
5r55s auto to TR3650 Manual swap 4.0 V6
  • Thread starter Thread starter Ceskz
  • Start date Start date Feb 24, 2025
C
Ceskz
Italy
Feb 24, 2025
  • Feb 24, 2025
Hi everyone!
I have a 2005 V6 with a dying 5r55s....so now, i'm willing to swap a manual trans in it..i've already have the GT rear end to use with the trans and driveshaft, but I'm looking to collect all the informations to get the swap in the title done..so, first of all..does anyone have any information on it, and on how to do it?
Second, i've made a list down here with all the pieces i,at present time, know that are needed for the swap...could you please add the stuff that i'm missing/give me more informations on all of them?
Parts needed:
-TR3650 manual transmission
-Adapter plate to mate the tr3650 Bellhousing with the 4.0 block
-GT shifter, top side
-GT shifter boot
-GT Knob
-clutch line
-Clutch/brake pedal assembly with clutch switches
-Clutch master cylinder
-Clutch cable jumper wire/harness from pedal to under-dash connector(i think it should be from a V6 manual,correct me if i'm wrong)
-Clutch(don't know precisely what type, but i know Specs could make them..i need one that will fit the 4.0 pressure plate)
-GT Driveshaft(i've read also that the one used in an auto trans car fits with the tr3650 because they're of the same lenght..someone could shed a light on this?)
-Manual PCM from a same year mustang V6, where you have to disable/reprogram the PATS (also here, i've seen a couple of vid's on the web where some folks were showing that using HPTuner or the SCT Racing tuning software you could disable the auto trans features and so use the auto PCM you already have..true or not?need more info here)
-Engine/Trans Harness from a same year Manual V6 (also here, looking at the same swap in the GT section, i've read that you could reuse your auto harness, modifying some connectors/soldering some wires..but i need more information on the matter to understand what i have to modify,what connectors, and so on..also i haven't understood if i need the connectors from a manual V6,or from a manual GT)
Thanks everybody for all the help you could give me!!
89ripper
926
308
103
Rockford, Illinois
Mar 12, 2025
  • Mar 12, 2025
Did you ever find any information on this? Just a friendly bump for you
C
Ceskz
Italy
Mar 13, 2025
  • Mar 13, 2025
Thank you for the bump!
Unfortunately, nobody jumped in..considering this swap have been made multiple times for sure, I'm a little sad about..but whatever..let's hope somebody will answer someday..
89ripper
926
308
103
Rockford, Illinois
Mar 26, 2025
  • Mar 26, 2025
I dont know where you are at with this but I found this link:
5R55S auto to manual conversion
This is my first real post here, so be gentle…and yes, I did search, but most posts are about 5 speed manual to 6 speed manual swaps or inherently week auto to inherently strong auto swaps…So, assuming the Tremec T56 S197 Magnum actually sees the light of day, what would it take to covert my...
www.s197forum.com
Apparently someone posted a guide on here but the link doesnt seem to work anymore.
Reactions: Ceskz
Admin Dude
Jan 4, 1985
43,178
21,344
234
Box behind Walmart
Mar 27, 2025
  • Mar 27, 2025
www.s197forum.com
Here it is: https://stangnet.com/mustang-forums/threads/auto-to-manual-trans-how-to-guide.783401/
Reactions: Ceskz and 89ripper
89ripper
926
308
103
Rockford, Illinois
Mar 27, 2025
  • Mar 27, 2025
I was gonna summon you but I somehow knew you be watchin
C
Ceskz
Italy
Mar 27, 2025
  • Mar 27, 2025
Thank you both..I've already read the whole thread,and pretty sure the hardware side of the no job is the same also for the V6..the only thing I'm not sure about,is the wiring
89ripper
926
308
103
Rockford, Illinois
Mar 27, 2025
  • Mar 27, 2025
Didnt forget about ya! I watched the thread, usually only time I have to post on here is at night at work....go figure!
Reactions: Ceskz
manual swap
  • brockb
  • Feb 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 24, 2026
squeak93
F
5R55S Torque Converter Grinding while seating
  • feloniusgru
  • Mar 2, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 2, 2026
ctandc
C
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 21, 2026
R
Transmission for manual swapping a 1994-1995 GT
  • Rembrant
  • Jul 11, 2025
1994 - 1995 Specific Tech Jul 13, 2025
Rembrant
R
K
06 S197 V6 Engine Harness
  • KingN0thing32
  • May 9, 2025
2005 - 2014 Specific V6 Tech May 20, 2025
89ripper
