67suspension?
  • Thread starter Thread starter chad.c
  • Start date Start date Jan 30, 2007
C
chad.c
  • Jan 30, 2007
What options do I have on stabilizing or improving steering on my 67coupe? (before I do a disk conversion)
BornInAFord
199
Bend, OR 97701
Jan 31, 2007
  • Jan 31, 2007
A roller idler arm will help ease steering, even with power steering (I paid ~$30 on ebay for a new one from Moog). You can get roller conversions from opentrackerracing.com, too. Also, a steering box rebuild from stangersite.com will renew your box (for less than $200), or you could get a replacement box from a Flaming River vendor for $400-500. Make sure there is no binding in the steering linkage, either. Finally, a good performance alignment with 2-3° positive castor, 0-1° negative camber and 1/8" toe will help stabilize the steering make the car track better. Tire size and ratio will make a difference--do you have the stock replacement (for the original bias ply) 14" radial tires or have you upgraded to 15+ inch wheels with better aspect ratio? Change the stock steering wheel for a more modern one for better feel, too.
Do you have manual steering? Does the car wander at speed? What do you expect when you say "stabilize" and "improve my steering"? Are you looking for a more modern type driving experience like a rack and pinion can help give?
Daniel
BornInAFord
199
Bend, OR 97701
Jan 31, 2007
  • Jan 31, 2007
If you are doing a disc conversion that involves replacing the spindle (like the discswap.com one or actual used ranada setup), wait to get the alignment done...
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
