68 289 C code engine tips!
  • Thread starter Thread starter Crs
  • Start date Start date Jan 24, 2007
Crs
182
San Francisco, CA
Jan 24, 2007
  • Jan 24, 2007
I'm in the process of getting my engine rebuilt. I'm looking for a healthy combo with excellent throttle responce that will give me the most out of my block without being a gas hog. I have 3.50 gears in the rear with a C4 2500 stall(I may ditch to smaller stall). I just sold my 393 stroker.....so i'm building my original 289. Thanks!
Cobain03
996
Lexington, Ky
Jan 24, 2007
  • Jan 24, 2007
my mods are in my sig and i only get 10 mpg in town.
Crs
182
San Francisco, CA
Jan 24, 2007
  • Jan 24, 2007
Are you still using stock heads? Is there anything with your combo that you would change if you could?
J
JEE740
18
  • Jan 24, 2007
Crs, what kind of MPG were you getting with your 393? I'm just curious, since people can have different opinions on what a "gas hog" is. Also, what kind of performance were you getting from your previous combo?
Cobain03
996
Lexington, Ky
Jan 24, 2007
  • Jan 24, 2007
stock heads, but worked a little bit. there are slightly larger valves.
i have a weird situation where i think i have the wrong headers and i had to jack my engine up about an inch for the secondary tubes to pass the inner fender towers, also my hood scoop is bolted on with about 1 inch bolts sticking on the underside of the hood. i dont even want to explain why cause there is no resonable answer.
because of that i have major clearance issues. if those two items were out of the way, i would go performer RPM intake with performer RPM heads to match the specs on the cam (same as the performer RPM cam). i would put 3.50s in the rear (currently 2.80) with a 5 speed. the RPM package dyno sheet from edelbrocks website says 367 horse 340 torque. thats QUITE a bit difference lol.
Crs
182
San Francisco, CA
Jan 24, 2007
  • Jan 24, 2007
On my 393 , i was getting 7-8 MPG normal driving with occasional flooring of the pedal. The person who built the engine said it was a 400 hp motor with a mid 12 sec capability...........................never took it to the track though!
Thanks for your input Cobain ! I was thinking about a Crane Energizer 272 or a similar Comp Cam, with my stock heads cleaned up and the comp ratio bumped up a bit . Maybe the Edelbrock Package might not be a bad option either........... but i wonder how fuel efficient it is?
C
C0V3R
524
Australia
Jan 25, 2007
  • Jan 25, 2007
An overdrive will do as much for you as any build ever will. Consider putting in an aod or a t5 at the same time if you can stretch the extra.
Crs
182
San Francisco, CA
Jan 25, 2007
  • Jan 25, 2007
I will consider
jadesville
the polarbear conservation corps protects a polarb
20+ Year Stangneter
Oct 8, 2003
2,189
Gresham, OR
Jan 25, 2007
  • Jan 25, 2007
The C4 is what is killing you, I could only best 6-7mpg on highway with mine.
Overdrive, AOD or T5 will be a major improvement. Vacuum secondary carb (with an automatic), later model heads.
Cobain03
996
Lexington, Ky
Jan 25, 2007
#10
  • Jan 25, 2007
  • #10
in all honesty, if your building for gas mileage, your building the wrong engine lol. get a 4 banger
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jan 25, 2007
#11
  • Jan 25, 2007
  • #11
The 393 in my sig gets 14-15mpg with careful (boring) driving and normally around 11mpg with lots and lots of flogging--with a 1:1 ratio toploader, 3:70 gears, and 26" tall tires.
When I had a basically stock 351w in the 65' it got 19mpg using 3:10 gears.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
J
68 Mustang with Foxbody Engine Stalling Issues - MSPNP2
  • JayV68Stang
  • Mar 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 13, 2025
JayV68Stang
J
Engine Chasing a badly idling/dying engine.
  • ziegenfuss
  • Feb 20, 2022
2K
Classic Mustang Specific Tech May 27, 2022
manicmechanic007
T
2002 GT Engine Sputtering Under Load ONLY, Vacuum advance problems?
  • thatSparkyAJ
  • Jun 17, 2022
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Jul 20, 2023
Yel2002GTAuto
Y
J
68 power steering pump
  • jadip60
  • Oct 5, 2020
Classic Mustang Specific Tech Nov 30, 2020
70mstang
