812 rwhp, 92 Ford Mustang GT, 347cid, D1R Procharger, Tremec 6spd, 140k on car, about 2k since build. I have dyno sheet and video for 683rwhp, but not for 812rwhp after supercharger upgrade, intercooler upgrade, and spraybar addition.
Performance
•FMS R302 Block
•CHP Track Dominator 347 Stroker w/ forged Crank,
H-Beam Rods, 8.5:1 Pistons, internal balancing
•Romac Harmonic Balancer
•McLeod Aluminum Flywheel
•Centerforce Dual Friction Clutch
•Lunati 51012 Camshaft
•FMS 1.7:1 Roller Rockers
•TFS Pushrods
•Crane Lifters
•TFS Twisted Wedge Heads
•Coast High Performance Polished EFI Super Spyder
Ported and Polished by Extrude Hone
•90mm Accufab Throttle Body
•Pro-M MAF Meter and Calibrator
•MSD 50lb Injectors
•Aeromotive Jumbo Rails, Regulator and Fuel Pump
•½” Fuel Line Conversion
•MSD Distributor
•MSD 6A Box
•FMS Valve Covers
•Nitrous Express N-Ter Cooler Chiller’
•Perma-Cool Oil Cooler and Electric Fan
•TurboXS H-RFL Blow off Valve
•Torque Master Coil and Spark Plugs
•Nology Hotwires
•March Aluminum Pulleys
•Flex-a-Lite Dual Electric Fans
•BBK 1 ¾” Long Tube Headers
•BBK 2 ½” Off Road H-Pipe
•MAC 3” Cat Back Exhaust w/Chrome Tips
•Borg Warner T-56 Six Speed Transmission
•Aluminum Driveshaft
•Drive shaft Safety Loop
•3.73:1 Gears
•Saleen Rear End Girdle
•5 Lug Conversion
•Baer 13” Front Rotors, Crossdrilled, Slotted, Zinc Washed
•Baer 12” Rear Rotors, Crossdrilled, Slotted, Zinc Washed
•Energy Suspension Motor Mounts
•Energy Suspension Transmission Mount and Crossmember Mount
•Procharger D1R Supercharger with 12-rib belt
•w/ 3.70” S/C Pulley @ 17 psi (Manifold)
•Procharger 3 Core Sheetmetal Intercooler
•Renegade bracket setup
•Moroso 7-Quart Oil Pan
Exterior
•Saleen Spoiler
•LX taillights
•Centerline Saber Wheels 17x8 & 17x9.5 rear
•Cervin’s Stormin Norman Hood
•BBK Strut Tower Grace
•Suspension Techniques Front & Rear Sway Bar
•Racecraft Springs
•Koni Adjustable Struts
•Racecraft Shocks
•Racecraft Quad Shocks
•Racecraft Shock Tower Brace
•BBK Upper Control Arms
•South Side Machine Lower Lift Bars
•Energy Suspension Bushings
•Racecraft Aluminum Offset Rack Bushings
•Racecraft Subframe Connectors
•Flaming River manual rack & pinion
Interior
•Maximum Motorsports 6 point Roll Bar w/ Swing-Out Door Bars
•Flofit Seats
•9 Autometer Gauges
•Grant Steering Wheel
•Pro 5.0 Shifter
•Hurst Shifter Plate
•Aluminum Window Switches from UPR
•Aluminum A/C Knobs from UPR
•Aluminum Ashtray Switch Panel from UPR
•Aluminum Door Handles and Bezels from UPR
•Auto Custom floormats w/ Running Horse
•Alpine 3339 Equalizer
•Accelevision Motorized 7” Flip Up Monitor
and DVD Player
•Linear Power 5002 Amplifier
•Precision Power Amplifier
•Zeus 12” Subwoofer
•Alpine 5”x7” Separates
•Pioneer 6.5” Separates
•Polk Audio Tweeters
•Streetwires Power Kit, Wires & Distribution Block
•Moroso Battery Box and Optima Battery
•Sullivan Racing Aluminum Shift Knob
•Lonza Aluminum Pedal Covers
The Bad
·Paint could use touchup in spots
·Front bumper cover should be replaced to look better
·Rear tint peeling
·Needs crankcase evacuation system
·Rear tires are getting hard
·For better drivability computer should be flash tuned
·Having issues with head unit for stereo/tv
Car has about $100k put into it between parts and labor. Priced for quick sale $15k. Call/text Adam @ (623) 341-3843 Located in Peoria, AZ
