'85 roller questions
  • Thread starter Thread starter qazvick
  • Start date Start date Aug 21, 2005
Q
qazvick
  • Aug 21, 2005
Hey guys I'm hoping you can help me out here.
I have an '85 302 roller motor that I'm rebuilding so I can install in my '87 Mazda RX-7. I'm having a problem with the timing chain set. I need to know whether or not it's an HO or not. Thing is, I have no clue if it is or not. I assumed it was an HO if it's a roller and came out of an '85 mustang. I also don't have the original timing gears/chain unfortunately so I can't match part numbers. Here's what I do know. It's a 1985 roller block out of a mustang, with casting number E5AE. Can any of you help me out? Thanks! I need to get this beast one the ROAD!!!
txstang84
1,639
42
69
Tuscola, tx
Aug 21, 2005
  • Aug 21, 2005
i've used both kinds, on differing years, if you are going carbed, you'll need to specify that when you buy the part, unless you plan on running an electric fuel pump...last time i remember using one, they were slightly thinner to allow more clearance for the fuel pump eccentric...once again, this is dependant on your fuel system setup. but as long as it's for a 302, you should be ok
txstang84
1,639
42
69
Tuscola, tx
Aug 21, 2005
  • Aug 21, 2005
oh-and welcome to stangnet!
Q
qazvick
  • Aug 22, 2005
Thanks... Is it possible to go electric fuel pump w/ carb? That that just hit me... I definately want to go carb on the motor.. should I just get a diff chain cover so I can do a mech pump? As of right now I was thinking about wiring up the intake fuel pump and then using a pressure regulator... good/bad idea?
NosPony
278
Canton, Il
Aug 22, 2005
  • Aug 22, 2005
If the motor is a roller motor its a HO. If it came out of a 85 5 speed its a roller and if it came out of a 85 auto its a non roller.
Yes, you can go with a electric pump. Just block off the mechanical pump hole in the timing cover.
Q
qazvick
  • Aug 22, 2005
Awesome. Thanks for the help guys.
C.Harris
Da Boss
1,850
  • Aug 22, 2005
Also, in case you weren't aware, be sure that if/when you go to an electric fuel pump that you buy one designed to work w/a carburetor. Typically, pumps that deliver more than 7 psi at the carb will exceed the needle and seat capacity on most Holleys. A regulator can also be used in conjunction with the pump to help dial in the pressure you need.
Fishhawk
281
Michigan City, Indiana
Aug 22, 2005
  • Aug 22, 2005
As far as I know if its a roller it an HO.
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
R
Unidentified Ticking Noise
  • revised
  • Jul 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jul 11, 2026
MT94GT
