88 Convertible - Suggestions on how to repair the seatbelt opening on rear trim
lemosley1973
142
43
38
47
Clover, SC
The openings where the seatbelts come out of the rear trim are pretty chewed up. I'm missing the black trim piece on the passender side; I have it on the driver side, but the problem is the underlying opening is damaged enough that the trim pieces have nothing to screw into.
Any ideas on how to build this up so I can screw trim pieces to it? I saw what Dave did with rebuilding a portion of the rear 1/4 trim that had UV rotted. I"m not sure that will work for this scenario since you have a seatbelt sliding through the opening.
Also, how about repairing cuts in the vinyl as in the second picture? Eventually I'd like to go all black for the trim pieces and carpet (with white seats). Has anyone recovered the rear trim pieces?
  • Sponsors(?)
lemosley1973
142
43
38
47
Clover, SC
OK let me approach this from another way - the material that is covered is ABS plastic or something else? How can I tell?
Then the question becomes what is the best way to bond to that material underneath? I'm thinking bond a she to the material undearth (maybe precut the sheet) the nbuild up where I need to?
lemosley1973
142
43
38
47
Clover, SC
Thanks Dave - I remember reading that - will PBA work on this plastic? Its black thermoplastic based on the link that was is in this thread - does PBA work on that type of plastic
PS: Masterful job on that bumper. I'm about 1/3 through that thread.
Davedacarpainter
I think I've messed my pants
SN Certified Technician
Nov 28, 2015
11,890
11,343
193
57
Discordia
It'll work on just about anything.
Being a plastic repair though, I recommend you use a plastic adhesion promoter prior to spreading the pba. You can get it in spray cans or wipes (3M). Spray or wipe it on just prior to using the pba, allow it to just dry (maybe five minutes).
You'll want to score the surface with a really heavy grit sandpaper. Like 40 grit.
The pba sands very easily once it hardens. Though it'll take an overnight of sitting before it completely cures.
The cliff notes edition is the way to catch up on my car, you can avoid all the bs of the regular thread. Though i did enjoy a lot of the bs truthfully.
Thread starter Similar threads Forum Replies Date
D Convertible sound deadening and insulation suggestions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
D Fox Torque converter suggestion 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
TheNudeLion Problem Suggestions. (new 95 Gt) 1994 - 1995 Specific Tech 2
koala33 91 Convertible Exhaust Suggestions (too Stinky) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
jerry S Seller suggests a 2800-3000 stall torque converter. Do you experts agree? Classic Mustang Specific Tech 16
S Virgin 1990 5.0 Convertible...suggestions Fox 5.0 Mustang Tech 15
D Converter Suggestions Fox 5.0 Mustang Tech 1
9 Convertible Won't Open - Any suggestions??? 1994 - 1995 Specific Tech 12
1 Any suggestions on Stall converter? Classic Mustang Specific Tech 5
D Delete 2nd Cats & Pass Inspection? 1996 - 2004 SN95 Mustang -General/Talk- 4
C Convertible windshield replacement 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
S 2005 convertible v6 2005 - 2014 S-197 Mustang -General/Talk- 4
R 1987 GT Convertible - Mystery plug 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
C 87 Convertible pump and cylinder replacement 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
J 2001 Ford Mustang Cobra SVT Convertible Fuel Smell help 1996 - 2004 SN95 Mustang -General/Talk- 2
J New '65 convertible owner The Welcome Wagon 4
gearhead77 89 (and prior) convertible sidewall speakers. Mustang Sound & Shine All 0
F What's it Worth? Red on red 1984, GT vert, 5.0, 26k miles What is it Worth?!?!? 0
K Rebuilding my 82 convertible fox body 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
C Progress Thread Project Low buck GT convert 1996 - 2004 SN95 Mustang -General/Talk- 5
S What's it Worth? 2007 GT Premium Modified What is it Worth?!?!? 1
M Loose driver's side glass 65 convertible 1965 - 1973 Classic Mustangs -General/Talk- 0
G 1965 mustang convertible price What is it Worth?!?!? 2
R 07 mustang gt convertible back seat delete 2005 - 2009 Specific Tech 0
K What's it Worth? 87 Fox GT What is it Worth?!?!? 11
C 2005 convertible top won’t go back up 2005 - 2014 Specific V6 Tech 0
gearhead77 Interior and Upholstery 89 GT convertible quarter window help Fox 5.0 Mustang Tech 5
Eilermoon '03 Convertible top stuck SN95 4.6L Mustang Tech 16
mustangmccance Progress Thread 89 convertible. summer driver 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 40
H 1972 convertible pre-purchase question 1965 - 1973 Classic Mustangs -General/Talk- 8
G 1965 convertible windshield upper molding 1965 - 1973 Classic Mustangs -General/Talk- 0
T Disable parking brake for convertible top 1996 - 2004 SN95 Mustang -General/Talk- 1
T Help Choosing a Torque Converter Aod 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
T Body Kit Fitment later fox body convertibles? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
G SOLD Convertible motor mounts Drivetrain Parts 6
R Progress Thread Just another 93 convertible project 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
D Need Help with wiring an 87 GT Convertible Radio Fox 5.0 Mustang Tech 30
R Fox Need advise 93 5.0 convertible prodject 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
H 1986 converted to 5.0 runs like sh## Fox 5.0 Mustang Tech 4
marcelo Fox Torque converter for AOD trans 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
1989FoxFan Interior and Upholstery How to replace convertible top frame rails Fox 5.0 Mustang Tech 2
1989FoxFan Interior and Upholstery Are there any good videos or guides for replacing convertible top Fox 5.0 Mustang Tech 9
1989FoxFan Electrical How to Remove Convertible top Motor? Also where is a good place to send it to be rebuilt Fox 5.0 Mustang Tech 14
S 01 v6 very dash wiring issue SN95 V6 Mustang Tech 4
H Anyone have any info on putting a 86 svo doghouse on a 93 convertible? The Welcome Wagon 0
H Anyone ever heard of putting an entire SVO front doghouse on a 93 convertible? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 56
D Selling advice for 2007 California Special Convertible What is it Worth?!?!? 1
J Setting gaps on a 66 convertible body 1965 - 1973 Classic Mustangs -General/Talk- 2
C Convertible part crossmember The Welcome Wagon 7
EX-SSP Coupe and convertible trunk liners 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
