  • 2.3L (N/A & Turbo) Tech
89 2.3 n/a
  • Thread starter Thread starter tregore
  • Start date Start date Aug 15, 2004
T
tregore
  • Aug 15, 2004
arghhhhhhhhhhh. ok I feel better now. Well my problem is that I had no hood on my stang. And someone messed with my plug wires the other night. Well I got them all straightened out and running again(quite rough running when this problem happened) I put it in reverse to back out and then in drive. as soon as I put it in drive I felt a snap and the car went nowhere. Reverse still works but od d 2 and 1 I get no forward movement at all. I checked my linkage and all looks fine/moves fine. Any ideas except that my drive band broke??? and if so will an automatic transmission from an 84 289 Ltd bolt up to my bell housing or to the motor. I really dont have the money for a rebuild and its my only car :damnit: any ideas would be awesome, im at a loss here
mr_woodster
1,314
Riverside, CA
Aug 16, 2004
  • Aug 16, 2004
As you will find suggested 1.3 trillion times, do a search on a t-5 swap. The a4ld auto trans really blows...in the most literal sence. Even after a quality rebuild it still eats itself. The best, easiest, cheapest and most effiecent swap is a 5 speed from a 2.3 86-93 mustang/tbird (n/a or turbo). Local junkyards (if you pull it ) i have seen them as cheap as 50$.
JamesBaumann
624
Vancouver Island
Aug 16, 2004
  • Aug 16, 2004
Sounds like that A4LD is done like dinner. You could probably take it to a tranny shop and get it diagnosed quickly to see if it was easily reparable or not. Keep your fingers crossed considering this is your only car. Not to sure about the tranny from the 289. I'm assuming that the input shafts will be different sizes, among other things. I really don't think that will swap in too easily. If you have the time and the ability then look at doing a t-5 swap, they will give you a lot more power at the rear wheels and will make driving a lot more fun. Here is a link for a auto to manual swap in your car:
http://projecthp.ford23.com/howto.html
Hope some of this helps and feel free to ask any more questions about anything.
Oh, any by the way, you might want to invest in a new hood as well.
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
